1dogandnoexes
- Jan 20, 2019
I have a lifting cable on my blast cabinet door which had failed in the past. I got it operational with wire rope clamps from Home Depot. The door is quite heavy and so is the corresponding counter weight (Hmmmmm...). A cable failure while arms or something else is in the blast cabinet is almost certain to cause a serious injury. One end has a thimble and is swaged. The other is terminated with no swage. I can source the materials from McMaster Carr at least, and can also choose a ferrule with more compressions than the original. I don't know, however, if my garden variety handheld swaging tool (14" long levers) will produce the required result. The original has lasted from 1966, so it had a pretty good run. Thanks in advance for any input.
Can the moderator or someone else please tell me how to address the sideways image issue?
