52wrench
- Jan 28, 2006
- Buffalo,NY
I've been going thru a 1958 LeBlond Regal 13x40 manual shift. I did the apron and QC box, everything was fine. Over the w/e I'm draining the head oil to put in some fresh DTE 26 and I see what appears to be a roller from one of the bearings sitting on the bottom, WTF? I took off the cover when I bought it and looked at the gears and bearings it felt great when turned by hand. As it turns out the "roller" was actually a straight pin that locates the main gear cluster axially on the spindle. It goes into a hole on the gear hub and into a hole that is bored into the spindle. The hole in the spindle goes all the way thru to the center bore. The gears are also keyed to the spindle. When it came out it allowed any chips inside the spindle a direct shot into the case when they hit the hole. I took about a tablespoon of the stuff out. Amazingly the bearings all feel great with the exception on the input shaft, it feels a little rough probably because those bearings are the lowest in the case and may have got a chip or two. I've got the drive pulley off the shaft and the bearing retaining flange removed. I'm going to try a slide hammer to pull the shaft/bearings, if that doesn't work then rig up a puller with a piece of pipe and threaded rod. I guess the chips must have just sat on the bottom of the case, pretty amazing. Anyone got any suggestions on removing and replacing the shaft/bearings? Thanks.
Steve
Steve
