DIYProjectKits
- Dec 18, 2020
Link to our fully-funded Kickstarter, only ~8 hours left!
Original post on the r/machinists subreddit
Hopefully this is allowed! My wife and I are excited to say that our first product design has reached and even exceeded our funding goal on Kickstarter! Not a huge accomplishment, because we set a relatively attainable goal of $1,000, but we learned a lot and had to put in a lot more effort than we thought in order to even reach that small amount! This was a great learning experience, as will be the production & delivery phase. As of this posting, there are roughly 8 hours left to back it, so if any of y'all want one for yourself/someone else, please feel free to back the product at whatever level suits you best.
What exactly is a "Swiss-Army" 1-2-3 Block?:
It is a multi-purpose Machinist/Metalworking tool for all ages! This all-in-one tool contains the functionality of at least 6 distinct tools:
1. 1-2-3 Block. Blocks are accurate to 1.0000" x 2.0000" x 3.0000", +/- 0.0002"
2. Drill/Tap Guide. Use one of 8 precision-reamed holes as a tap guide on flat, round, or oddly shaped stock. Holes are sized to work with 16 of the most common Metric & SAE tap sizes, interchangeably.
3. V-Block. Use one of two V-Grooves on the block to securely clamp round pieces of stock in a vise for manual or machine operations. Two perpendicular V-Grooves allow for quick & easy horizontal or vertical part orientation. Groove are ideally located for use with standard 4- & 6-inch machine vise jaws.
4. Bench Block. Use the block as an anvil when driving pins in or out. Additionally, the holes can be used as a drill guide for both flat & round pieces of stock.
5. 1/4" Hex Driver. The magnetically-retained 1/4" Hex Drive turns this block into a venerable arsenal of tools, by allowing you to use a myriad of standard-sized tool bits, including: screwdrivers, drills, chamfer bits, deburring tools, socket adaptors, & more!
...and last but not least...
6. Bottle Opener. Bottlecaps removed using this tool suffer from ZERO deformation, due to the wide 1" contact surface of the block, which disperses the opening forces over the entire face of the bottlecap - a handy addition for bottlecap collectors!
Several backers have suggested custom blocks, matched sets, etc., so if you want something slightly different, let me know and we'll make it happen!
