There are two types of T12 lamps, rapid start and instant start. Rapid starts have filaments on each end to ionize the mercury in the tube and do use power. That's the reddish glow at the end of the tubes. The tubes and fixtures are identified by having two pins on each end of the tube. Same for the fixture, the tombstones have two openings. Instant start tubes only have one pin on each end. The have no filaments. Magnet ballasts are special design transformers that provide a high voltage to start the tube, then they regulate the current. Rapid start ballasts also provide the filament current. Electronic ballasts do the same thing, they use electronics instead of magnetics.
As to current being drawn, a fully functional fixture will draw current for the ballast, be it magnetic or electronic, filament current if it is rapid start and lamp current. Lamp current is the is the current that maintains the arc inside the tube which provides the light. Instant start do the same thing without the filament current.
So to answer your question, a fixture without lamps will draw a small amount for the ballast. A fixture with a dead lamp may draw additional current if it has filaments.
Tom
