T(?) studs, where do I find these
Results 1 to 15 of 15
    May 2018
    CANADA
    Quebec
    241
    238
    76
    Default T(?) studs, where do I find these
    Hey y'all,
    I bought a gently used Taiwanese 5" compound angle vise the other day. It's cleaning up well, except that the studs on the circular base were totally stripped out.
    These are probably a retrofit, as I believe they're the only imperial hardware on the vise. Looks like 1/2"-13, 1.5" tall with a turned base. 1" at the widest, 3/4" at the narrowest.
    Are these a standard item I could buy off the shelf someplace?
    Siggi
    Nov 2005
    Hudson Valley, NY
    1,007
    631
    Quote Originally Posted by sigurasg View Post
    Hey y'all,
    Are these a standard item I could buy of the shelf someplace?
    Siggi
    Is the internet a shelf?
    googled t slot bolt and got lots of similar items, but you need to determine if the size is right
    or if you have a lathe its a quick job
  3. Likes sigurasg liked this post
    Aug 2008
    Paso Robles, CA
    189
    72
    35
    A 1/2" x 13 standard bolt is 3/4" across the head flats. You could probably just mill those to the thickness you need.
  5. Likes michiganbuck, sigurasg, Thunderjet liked this post
  6. #4
    Feb 2007
    St. George, Utah
    1,402
    926
    977
    Quote Originally Posted by David Ferguson View Post
    But... that would probably allow the bolt to turn in the channel unless its tight enough to hold on short flats.
  7. Likes sigurasg liked this post
  8. #5
    Apr 2004
    Modesto, CA USA
    8,733
    1701
    How about a square head bolt?
    Bill D
  9. Likes Gordon Heaton, sigurasg liked this post
  10. #6
    Jun 2012
    Michigan
    14,122
    4813
    5089
    Quote Originally Posted by Bill D View Post
    Bill D
    I have used square heads and just hand snagged them on a bench grinder till they fit.
    Bolt Dimensions — Baden Steelbar & Bolt Corp.
    ref 3/4 SQ and 11/32 Thk.
    I think you have to thin the >11/32 to 1/4. (?)
    Be careful, bench grinders bite.
  11. Likes sigurasg liked this post
  12. #7
    Sep 2005
    Oakland, CA
    3,051
    620
    986
    I think every machine shop supply company in the world sells these.
    T-Bolts & T-Slot Bolts On TE-CO
  13. Likes sigurasg liked this post
  14. #8
    Jan 2003
    Imlay City, Michigan
    2,269
    132
    274
    Here's a previous discussion that shows the ones used in a Kurt vise.
    T-nuts for Kurt swivel base
    Or you could make your own?
    Made these to increase the clamp load of the fixture I was mounting to a Kurt swivel base.
    Kevin
  15. Likes sigurasg liked this post
  16. #9
    May 2018
    CANADA
    Quebec
    241
    238
    76
    Thanks everyone for your suggestions. I guess I'll need to measure the slots and see how wide the stud needs to be at base so as not to rotate in the slot. Maybe I can mill down regular 1/2"-13 T-slot bolts or square head bolts to a suitable size.
    I was surprised to see these stripped out like this, I can't imagine locking the circular base warrants that level of gorilla-torqueing the nuts?
    On a tangent, the vise has a tag saying "GS Taiwan" and it's a 3 way compound with 5 inch jaws (or maybe 125mm). I've done some searching to try and find any kind of information on the manufacturer, parts list or some, but so far I've come up empty.
    Anyone know who would have made those or where I might find a parts list (for my curiosity)?
  17. #10
    Jun 2012
    Michigan
    14,122
    4813
    5089
    there was a vise coming out of China about 10 years ago that a two-hand tightening could break the front jaw right off, and so it might land on someone's foot.
  18. #11
    Nov 2014
    Florida
    6,353
    2532
    3140
    Check McMaster Carr. probably have something close enough for a quick mod.
  19. #12
    May 2018
    CANADA
    Quebec
    241
    238
    76
    I turned some replacements this afternoon, just went by the same dimensions as the horked hardware. I guess we'll see how much gronk it needs to hold tight in use.
    I still don't think this is original as e.g. the screws holding the jaws in place are M8.
  20. #13
    Apr 2018
    8,999
    4351
    Quote Originally Posted by michiganbuck View Post
    Safety feature. That was the No-Crush vise for fragile work.
  21. #14
    Nov 2007
    marysville ohio
    10,729
    3006
    7426
    Well I sure hope you used metric threads on the ones you made, it would be tragic if it was not all metric!
  22. Likes sigurasg liked this post
  23. #15
    May 2018
    CANADA
    Quebec
    241
    238
    76
    Quote Originally Posted by moonlight machine View Post
    I just made it 1/2"-13 like what came off it, but I fear the old Deckel may reject it - or at least make fun of it.
