Laverda
Cast Iron
- Mar 24, 2014
- Riverside County, CA
I recently found a used Sunnen bore gauge setting fixture (0 to 2"). It looks in close to new condition. After setting the zero it reads .0003" off at 1" and .0006" off at 2" using gauge blocks. Yes I know due to errors in the screw thread, no micrometer is gonna read dead on at all points. But I was not expecting this much. If I zero it at 1" it is still off .0003" at 2". It measures the blocks as too small.
So .0003" off for every 1" of travel seems a bit much. My 60 year old Lufkin 1" to 2" micrometer measuring the same gauge blocks is only off only .0001" in a inch.
So what I am wondering, is this the expected result or do I have a worn out Sunnen micrometer? Having to put gauge blocks in it to calibrate it for whatever bore size I will be honing does not make it a very useful tool. I was hoping this would save time instead of using ring gauges or blocks.
