Takisawa Turning Center, TC-3 Error 12
Results 1 to 4 of 4
    Feb 2018
    Minnesota
    Default Takisawa Turning Center, TC-3 Error 12
    Takisawa Turning Center:
    Model TC-3
    Mach. No. THUX 7521
    Fanuc Spindle Servo Unit (Complete): A06B-6055-H112
    Fanuc, Spindle Drive (Front Board Only) P/N, A20B-1001-0120
    Fanuc A/C Spindle Motor: A06B -1012 - B (201)
    Error Code: ER- 12 (On Drive)
    1) Power up turning center (No errors). 2) Axis functions all work. 3) Motor Tach. Feedback works. 4) As soon as a command is sent to the spindle drive for rotation, ER-12 shows on drive board. (No chuck rotation visible).
    2) Circuit board A20B-1001-0120 replace with $800 board off of E-Bay, with swapped E-Prom chips. Same symptoms as #1)
    3) Can A/C spindle motor be tested with 3 phase power for functionality?
    4) Does anyone have a schematic of the ‘Over Heat Alarm” OH1 and OH2 circuit? Or, complete machine schematic?
    5) Does anyone know who would be capable of testing the motor and drive unit. Possibly in the Minneapolis, Minnesota area.
    6) Can motor be tested as a standard 3 Phase Motor?
    7) Any other ideas what could be causing this issue?
  2. Likes partsproduction liked this post
  3. #2
    Aug 2011
    Oregon
    2,466
    501
    728
    Friend, though it sounds like your problem is slightly different, look at this thread; Lathe still down!
    Mine was destroyed by a power spike, and a technician swapping spindle drives installed one for a non lathe.
    parts
    Dec 2013
    596
    208
    321
    Have you tried Takisawa? 847-419-0046 Maybe try starting with Brian Holm in Parts Dept..
    Apr 2005
    Beaverdam, Virginia
    6,730
    459
    3009
    What control? Fanuc what?
