smootz
Stainless
- Dec 5, 2005
- Southern Ohio
My shop air has been supplied by a Sanborn 5hp two stage 80 gallon compressor for many years. The only complaint has been the excessive noise that is characteristic of high speed aluminum pumps.
I just bought an Ingersoll compressor with the same specs except it has a nice, slow, quiet cast iron pump.
Rather than replacing the Sanborn, I have considered tying both compressors into the shop manifold. There would be check valves on both tank outlets. Setting the pressure switch a few lbs. under the IR should make the Sanborn act as a backup, coming on only during periods of high use. (ie. arc gouging - blasting).
Has anyone done this and what problems do you see?
SCOTTIE
SCOTTIE
