Tap drill for 3/8-28 tap - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21
    Sep 2010
    Oklahoma City, OK
    5,543
    1071
    2417
    Reduction from nominal to tap hole size is consistent across thread pitches, assuming they're of like form.
    Barring the book, just check the delta on a 1/4-28.
    Sent via CNC 88HS
  2. #22
    Sep 2010
    Oklahoma City, OK
    5,543
    1071
    2417
    Quote Originally Posted by plastikdreams View Post
    1/8 bsp straight.
    So 1/8 BSPP?
    Sent via CNC 88HS
  3. #23
    May 2011
    New Jersey
    2,994
    301
    1649
    Quote Originally Posted by triumph406 View Post
    and to cap it all a machinist who can't figure out the right diameter drill for a tap........
    Pretty much...that's why I asked. And if you actually READ my op I had an answer I was just double checking.
    Quote Originally Posted by Cole2534 View Post
    So 1/8 BSPP?
    Sent via CNC 88HS
    Sure lol like I said I have 0 experience with bsp
  4. #24
    May 2011
    New Jersey
    2,994
    301
    1649
    For sng here's picture from my mh for tap drill sizes for American thread forms
  5. #25
    Sep 2006
    Stillwater, Oklahoma
    1,810
    141
    1059
    I recalled that there were specs for BSP and BSPP - British Standard Pipe and British Standard Parallel Pipe. The first tapered as US pipe threads and the other not, so it's worth knowing more specifically what's called for.
  6. #26
    May 2011
    New Jersey
    2,994
    301
    1649
    Quote Originally Posted by TGTool View Post
    The one engineers reply was, if it's too lose we'll use Teflon tape...it's out of my hands now.
  7. #27
    Nov 2003
    5,967
    213
    2059
    My tap drill calculator will do 55 degree threads. Or any other angle.
    And 55 degree thread.....of course all of our first questions should be 'why' rather than just rushing for the solution
  8. #28
    Dec 2015
    Illinois
    621
    215
    390
    British Standard Pipe - Wikipedia
    G specifies parallel threads
    R denotes tapered threads
    WTH is going on in the UK?
  9. #29
    Apr 2004
    Modesto, CA USA
    8,635
    1653
    Us does the same with pipe threads. NPT are tapered. Conduit threads are straight.
    Bill D
  10. #30
    Dec 2015
    Illinois
    621
    215
    390
    But why G and R?
    Maybe derived from French words when they made it an ISO standard?
  11. #31
    May 2011
    southern in.
    1,652
    2160
    432
    Quote Originally Posted by Bill D View Post
    Bill D
    There are some straight threads used in large hydraulic stuff, usually using a copper washer in the bottom to seal.
    JH
  12. #32
    Mar 2020
    New Jersey
    41
    88
    9
    I haven't tapped 3/8-28 but have tapped 3/8-24. I used a Q drill for 75%. I would think the R drill would be fine. Also the formula as stated by at least two others say that major diameter ( 3/8 ) minus the pitch 1/28
    is a correct formula for a tapped hole. .375-.028 = .347
  13. #33
    Jun 2016
    New York
    2,157
    1742
    1060
    Bill D
    no, rigid conduit uses NPT tapered threads, when was the last time you threaded some together?
  14. #34
    Jun 2012
    Michigan
    5,987
    5642
    3813
    Here's a handy site for most things thread related.
    This page has all the info on BSPP threads.
    Thread Data Charts
  15. #35
    Nov 2012
    Wisconsin
    2,339
    3864
    2890
    Bsp wasn't even remotely in the equation...I've never even threaded anything bsp. Funny thing is, they brought me 2 taps and a similar part that would thread into the block. The nut on the part threaded onto the 3/8-28 a little loose but wouldn't even start on the bsp tap. Tapped a hole using the 3/8 tap and the part was very tight threading in, tapped a hole bsp and the part was just a little lose and the nut could be used to tighten it up. Crazyness...
    When stuff like that happens around here its typically because someone is "reverse engineering" (aka copying) something. then of course all the tolerances get tightened up to .001" because they have no idea what it really needs to be in order to work. So instead of actually engineering something and using a calculator they do whats easiest for themselves.....tighten it uo to make it exactly like the one being copied.....i mean reverse engineered,,,lol
  16. #36
    Aug 2005
    CT
    8,366
    457
    2230
    I didn't see 28 in my mh v28. But looks like the numbers match up. Looks like they are going to use a nut to tighten up some threaded suction cups to hold vacuum. I guess npt wasn't good enough
    May I make a Wild Ass Guess here?
    You're making a mating piece for a Festo push-in type fitting!
    If I was correct and won, then let me go for bonus points!
    You might be making a part for a FESTO BSPT(R/Rp) style combo, in which case your female thread is a BSPP, while the male thread is BSPT
    IOW, as-per FESTO specs, they want a 1/8-28 British tapered male fitting to fit into a 1/8-28 British straight hole.
    ( 'About to make the very same threads into some tubing, also for vacuum application on a German machine. )
  17. #37
    May 2011
    New Jersey
    2,994
    301
    1649
    Quote Originally Posted by SeymourDumore View Post
    Nah it's some kind of thread in suction cup.
  18. #38
    Jun 2008
    Bellingham, WA
    4,457
    1104
    2525
    The key thing is this is not really a load-bearing threaded hole. So, make it easy on yourself and use a larger drill for a 65% thread. There is not need whatsoever for a 75% thread in this application.
    Denis
  19. #39
    May 2011
    New Jersey
    2,994
    301
    1649
    I'll never know if it works, but I know I will if it doesn't
  20. #40
    Aug 2005
    CT
    8,366
    457
    2230
    Well, that does not exclude Festo from the list of culprits: Buy Vacuum suction cup VAS, VASB online | Festo USA
