Tap extraction
Results 1 to 6 of 6
Thread: Tap extraction
    Nov 2016
    Michigan
    45
    15
    Unhappy Tap extraction
    Any good advice on extracting a broken tap from part?
    Broke an M5 HSS tap in a piece of 304 plate and really want to not redo it.
    a very small piece is sticking out from the top.
    I have never had any luck getting them out and conserving the hole/part anyone have any advice?
    Sep 2004
    Sonora , Calif
    597
    121
    127
    Call Cammann inc. they make tap extraction machines and ask them if someone near you has a tap extraction shop. 877 965-4051.
  3. Likes Ray Behner liked this post
    Mar 2009
    Brunswick Oh USA
    4,656
    5305
    2783
    Ask for Hank. Unless he's retired by now. 440 965 4051.
    Jun 2012
    Michigan
    5,257
    4849
    3200
    Where in Michigan are you?
    Dec 2012
    Se Ma USA
    1,782
    144
    983
    Use a TIG welder. Be aware that the piece sticking out may or may not be connected to the rest of the tap below. They sometimes shatter.
    Wit TIG torch melt the tap end just a small bit and then start adding filler. Bit of filler and cool, repeat until you have something to get a better grip on. The heat does help a bit too. Grab with vise grips and start to wiggle a bit. At some point it may come out but don't be greedy with the torque.
    You may also need very good ventilation depending on type of tapping lube you used.
    You can also drill it out with special drills made for this. Or buy the appropriate size masonry drill and sharpen the tip to work CCW. Cut the shank down as shout as possible so it is very rigid and have at it.
    Oct 2005
    18,304
    How did the tap break ?
