tap handle for 4-40 thread
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Apr 2004
    Modesto, CA USA
    7,480
    1310
    Default tap handle for 4-40 thread
    I need to tap a few 4/40 threads by hand. In the past I have used a small tee handle tap wrench. The kind with a collet. It seemed kind of of big and heavy with poor feel for the work. Is there a better choice maybe something more like a pin vice? OR would the torque be too much for that. What about using my cordless drill. It seems like it could easily snap he tap if anything goes wrong.
    Bill D
    Jan 2014
    Temecula, Ca
    3,276
    1396
    4259
    I use a pin vise for small taps
  3. Likes Ron Hofer liked this post
    Mar 2011
    ohio
    64
    12
    10
    Quote Originally Posted by Bill D View Post
    Bill D
    we have ones like this we use when we have a limited number of holes, and they never seem to big or gangley. If we are doing more we run a tension compression tapping head set up
    https://www.mscdirect.com/browse/tnp...SABEgLeqfD_BwE
    Mar 2009
    742
    23
    42
    Tap handles come in a range of different qualities and you don't say what specifically you were using. I find my little Starrett 93-A to be fine for that sort of work. It holds the tap firm and the t-handle isn't sloppy like on junk tap handles. That's where I find the most frustration comes is from using tap handles that have unwanted movement. It is also easy to remove the handle for those times that you want to use it like a pin vise.
  6. Likes DavidScott liked this post
  7. #5
    Sep 2015
    Ohio
    1,300
    861
    1304
    I've seen guys make their own. Just a knurled aluminum disc about 1" dia with a thru hole tapped from the side for a set screw.
    All taps 3.5mm/#6 and smaller have .141 shanks.
  8. #6
    Mar 2005
    Kansas
    7,904
    488
    3759
    Turn and knurl a small piece of round stock. Say 1"to 1 1/4" in diameter. Drill an appropriate sized hole so you can force it over the square on the tap. If you're tapping aluminum, it could be a little smaller. D2, it may need to be a little larger.
  9. #7
    Oct 2005
    CANADA
    Ontario
    1,278
    319
    460
    Starrett 93A works well:
    93A T-Handle Tap Wrench
  10. #8
    Feb 2004
    peekskill, NY
    25,327
    5173
    The weight of any trap wrench at all, alone, can snap off a small tap.
    Electronics person tip: take several small knobs from your junk box. Install a small tap into each one.
    Starting with 0-80, up to about 8-32 or so. You may need to make an adapter bushing for some of the sizes.
    That's why you have a lathe....
  11. #9
    Oct 2010
    Dewees Texas
    2,593
    29
    757
    Quote Originally Posted by Booze Daily View Post
    Great minds think alike gbent posted at the same time. I have used these things on manual lathes and mills as well as CNC. On the lathe when cross drilling and tapping, a broken tap would have scrapped the fixture. Never broken one with these drivers.
    The O-ring and a 1/8 steel ball keep the tap in the retracted position on a CNC lathe or mill while running.
  12. #10
    Jul 2012
    Washington
    3,079
    1234
    1295
    Starrett 93-A, used it last night to tap a 4-40 hole and that tap is still in it now. No idea if they are as good as they were 30 years ago though. Definitely a lovely tool.
  13. #11
    Oct 2013
    st,louis mo
    686
    356
    ANY SMALL CHEAP DRILL CHUCK WILL EASILY DRIVE A 4/40 TAP.OLD 1/4 CORDED ELELCTRIC DRILS ARE TRACH CAN ITEMS. Take the chuck off and throw the rest back in the trash where it belongs.Edwin Dirnbeck
  14. #12
    Nov 2019
    CANADA
    Ontario
    83
    17
    11
    Bill D
    I bought a set of lisle tap holders that fit onto rachet wrenches of all sizes. it was like $30
    70500 Tap Socket Set
  15. #13
    Mar 2009
    742
    23
    42
    If you really wanted to go gonzo an Albrecht Royal Sensitive Drill Feed shank with an appropriate chuck on it could be really nice depending on what exactly you're doing. Starts getting a little pricey at that point, though.
  16. #14
    Jan 2007
    Norfolk, UK
    19,875
    15323
    15597
    Us Brits would use an Eclipse E142
    https://uk.farnell.com/eclipse/e142/...rTechnicalDOCS
  17. Likes TedinNorfolk liked this post
  18. #15
    May 2009
    Canandaigua, NY, USA
    3,017
    151
    1381
    I never use T-handle wrenches to freehand small taps because it's a recipe for disaster. Starrett 162 pin vise, usually the D size, is the way to go.
  19. Likes Illinoyance liked this post
  20. #16
    Oct 2006
    Norfolk, UK
    884
    878
    358
    The little Eclipse is wonderful for the small BA sizes. My dad liked to use a Meccano tractor wheel!
  21. Likes Limy Sami liked this post
  22. #17
    Oct 2005
    Wilmington DE USA
    2,098
    328
    434
    whichever handle I'm using, I use a guide block if the work doesn't have a spindle to guide me
    I have several either rectangular or disk shapes with 1-2" of flat surrounding the tap hole
    Most of my tap breakage I have attributed to trying to straighten out a tap after starting
  23. Likes Limy Sami liked this post
  24. #18
    Sep 2002
    People's Republic
    4,455
    433
    2706
    Ditto the small tap wrench
    low mass is key
    you accidentally let go of the wrench and it whips around, tink. broken tap
    smaller is better
    anything that reduces the mass is key, so if knobs etc work for you go for it.
    and dammit use gun taps, or roll taps
  25. Likes Limy Sami liked this post
  26. #19
    Sep 2004
    south SF Bay area, California
    2,064
    158
    685
    My vote goes to the combination of a tap guide bushing and a pin vise with a jewelers-screwdriver-type rest for the operator's index finger.
  27. #20
    Oct 2005
    CANADA
    Ontario
    1,278
    319
    460
    Quote Originally Posted by Conrad Hoffman View Post
    Huh? Heavy handed are we?
