I am making light pole bases with a572 grade 50 steel 1.5” thick. I cut the plates, basically a 14” square with a 4” hole in the center, on my cnc oxy fuel table. I then need to drill and tap 4 through holes in the corners. I forget the exact size, but it’s either 7/8 or 1” corse thread. Also drill and tap one small blind hole, about 1/4”diameter. So far all I’ve done is drill the holes with a Milwaukee mag drill, using a template for hole layout, then hand tap the holes. I have an order coming up for 27 of these plates, with a possible 38 more to follow. There must be a better, faster way to do this. Methods I have considered: powered tapping arm, tapping head for the mag drill, tapping with impact wrench.
Ideally I would be able to retrofit a drill head on my cnc table (it’s a 5x10’ with water table made by shopsabre) to drill the holes automatically. The company that made the table can do it however I would have to bring the table to them. Problem is they are in Minnesota and I am in Alaska.
Any suggestions?
Any suggestions?
