Terry Keeley
Titanium
- Oct 18, 2005
- Toronto, Canada eh!
I have to press a hardened and ground A2 sleeve onto a Thomson shaft with a tight 8-9 tens press fit (15mm bore).
The sleeve was double tempered at 500F for Rc60 hardness, if I heat it to 300F for the press will I screw up the temper? Should I heat it to 500F for the press? Does it matter?
http://www.crucible.com/PDFs/DataSheets2010/dsA2v12010.pdf
