In terms of Malleability, which grade of stainless is closest to copper?
Results 1 to 13 of 13
    May 2006
    Illinois
    230
    88
    38
    Default In terms of Malleability, which grade of stainless is closest to copper?
    I'm working of a medical device and am looking for a stainless wire around 20 gauge diameter that will bend and roughly hold its shape similar to copper. I want to minimize memory in the material as much as possible.
    What would be the closest grade of stainless to use?
    gm
    Jul 2014
    Ontario, Canada
    1,027
    731
    662
    They are two completely different alloys. Stainless will strain harden to a greater extent, that property is not comparable.
    May 2006
    Illinois
    230
    88
    38
    Quote Originally Posted by RC Mech View Post
    Thanks for the reply.
    I realize they are completely different alloys. Maybe I should simply ask which grade of stainless is the most malleable?
    gm
    Dec 2014
    CANADA
    British Columbia
    1,276
    361
    584
    304 is the usually go to for stamped and drawn stainless products so industry must have a reason.
    Oct 2011
    West-Central Illinois, USA
    1,212
    1958
    549
    The 3XX stainless work harden so when you bend them it takes more effort to bend them back. You only have a few bites at that apple before the material fails.
    Good luck,
    Matt
    May 2006
    Illinois
    230
    88
    38
    Quote Originally Posted by Matt_Maguire View Post
    Good luck,
    Matt
    Thanks for the feedback.
    Jul 2006
    Hillsboro, New Hampshire
    7,204
    1686
    4978
    Aircraft Spruce has stainless safety lock wire in a variety of sizes, and being meant for tight wrapping around screw heads it's a soft temper. Cheap too...
    SAFETY WIRE - STAINLESS STEEL - 1 LB SPOOL from Aircraft Spruce
    May 2006
    Illinois
    230
    88
    38
    Wow...at that price, its well worth picking some up to experiment with. Thanks for the link!
    gm
    May 2012
    Pittsford, NY
    1,006
    699
    655
    There's a constant for materials known as the strain hardening exponent ( Strain hardening exponent - Wikipedia ). There's more discussion at this link: Work hardening - Wikipedia . The larger the exponent, the higher the rate of strain hardening.
    Here's a table of the exponent that I found. Annealed copper is listed as .54, 304 as .45, 410 as .10, 17-4PH as .05.
  10. Likes gbent, gmoushon liked this post
  11. #10
    Dec 2004
    uk
    14,057
    4552
    6699
    Biggest issue most common stainless wires going to be in as drawn temper and thats pretty dang springy, annealed stuff is noticeably less, 304 or 316 are both pretty similar though in my experience.
  12. #11
    May 2006
    Illinois
    230
    88
    38
    I took Milland's advise and ordered a 1# roll of .025 SS annealed wire. Cost me $20 shipped. Will experiment with that and see.
    Another option I thought of is to use silver wire from a jewelry shop. From what I understand, the only metal that is more malleable that silver is gold. Just not sure how its surface will stand up to the autoclave process. This is going on a surgical device.
    gm.
  13. #12
    Oct 2011
    1,212
    1958
    549
    Quote Originally Posted by adama View Post
    Safety wire is fully annealed (quenched in the case of 302-304). Basically used just once & tossed for new if re-torque is required. Gets pretty stiff the first time you twist it and seriously stiff buzzing around in an airplane after a few hundred hours.
    Good luck,
    Matt
  14. #13
    Nov 2009
    Massachusetts
    282
    79
    Default Surgical stitch wire is type 316L
    When closing up after open-heart surgery, they put the sternum back together with six stitches through the bone using stainless steel wire. The sternum was sawed in half aling the vertical centerline. The alloy is 316L.
    Corrosion of stainless steel sternal wire after long-term implantation | SpringerLink
    Wire stitches can also be made of pure titanium (permanent) or a titanium alloy (dissolves after six months or so).
  15. Likes muckalee liked this post
