atomarc
- Mar 16, 2009
- Eureka, CA
This may be a silly question but I can't quite get my poor head around it.
If I have a shaft with a bearing at each end and I apply a force of 1000 pounds evenly to the shaft (radially), will each bearing share that load and see only 500 pounds of force? Probably not, huh!
I guess it would be akin to putting each foot on a bathroom scale and expecting each scale to read 1/2 your total weight. Probably not, huh!
I have spec'd many casters over the years and the SOP is to take the total expected weight and divide it by the number of casters..hence, a 8K weight would require 4 2K casters. What I don't understand is the difference between the first two scenarios and this caster scenario
Keep in mind I only made it to the 4th grade before reform school!
Stuart
Stuart
