Is there anyone here who builds custom engines? I would like to build a prototype - Page 15
Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 281 to 300 of 305
  1. #281
    Dec 2012
    AUSTRALIA
    2,394
    10
    748
    Which is why Toyota and others are working on liquid fuelled fuel cells....some hydride like ammonia will be the fuel,produced from petroleum oil with the carbon used for (maybe) "various things"..The Saudis are putting billions into this for obvious reasons.Electric cars,just a different scheme.
  2. #282
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,292
    1193
    707
    Quote Originally Posted by Gobo View Post
    YouTube Here you go.
    Looks like that just gets you a roughed out crank, he would still need a crank grinder to finish it, if he gets rid of all the wood shop equipment he might just have enough room for both of those
  3. Likes eKretz, Gobo, Turbowerks liked this post
  4. #283
    Dec 2012
    AUSTRALIA
    2,394
    10
    748
    Dont need all that stuff----a restorer made a crank for a Henderson motorbike with just a lathe and a welder.....he also organized having a crankcase pair cast to replace the badly corroded Heathkit cases.
  5. #284
    Aug 2005
    Tucson AZ
    6,406
    9673
    3017
    Quote Originally Posted by APD View Post
    Its a little more complicated than that.
    Using your melting point logic, how is it that nearly every car nowadays has an aluminum cylinder head when combustion temperatures are over 1200F ?
    How do diesel engines keep from melting when they have combustion temps of 2000 C?
    They have cooling systems for those castings. Perhaps you have noticed that none have an aluminum exhaust system?
    JST, I'm quite familiar with combustion turbines. I work on them. Even with bleed air and ceramic coated blades and water added the temp on the latest is around 1800F. They would love it higher since it is used to heat water in combined cycle applications. Durability is king though in power generation.
  6. #285
    Jun 2001
    St Louis
    18,069
    1922
    3058
    Ideally, the energy would be extracted from the charge to the point that the exhaust is not that hot, and you COULD have an aluminum exhaust.
    It is not practical to do that with most engines, so it is not done. With power plant turbines, or marine diesel, as you know, it is possible and even practical to extract more heat after the fact, even though it is not practical to do so in the cylinder or turbine. Exhaust heat boilers have been around for a long time in marine work.
    House furnaces for forced air systems these days have plastic pipe for a stack, and it vents out at ground level, no danger. They extract the heat, much easier because fairly low-grade heat is the product, I agree, but that sort of low temp exhaust was not always the case.
  7. #286
    Sep 2002
    People's Republic
    3,440
    296
    2238
    Quote Originally Posted by GregSY View Post
    "Um, what kind of logic is that?? You drive 15 hours a day?!
    If you drive 2hr / day = 730 / yr = 7.5 years to get to your 5500 number "
    It's a new logic called 'math'. The point is not how much a person actually drives - it's not a people issue.
    exactly
    My boiler runs 800 hours a year, it gets serviced once a year, mostly cleaning and a filter change
    It has run for 10 years with 2 minor issues that required changing a low dollar part.
    that is half a million miles at 60 miles per hour[mental image of my boiler at 60 mph]
    We really should not be so impressed with ICE engine longevity
    Especially with associated costs
    It would be interesting to see what long haul truck companies really get out of their engines.
  8. #287
    Jan 2005
    Houston
    5,736
    542
    2524
    I talked to a cab driver once who said he used to work as a mechanic for the New York City cop cars....he said they were 'hot seat' cars. As in, the seats never cooled down because they were used in rotation for patrol shifts and the engines were never turned off 24 hours a day, until they needed maintenance or broke.
  9. #288
    Oct 2005
    15,994
    Many commercial places are like this. Railroads, truckers etc.
    FWIW one year we had about -30f for 2 weeks, many of the diesel pick up trucks left them idle all night.
  10. #289
    Oct 2009
    Oregon
    4,422
    4757
    2289
    A good friend worked for Crowley in Prudhoe Bay for a few years. They had a fleet of Ford 6.0 Powerstroke trucks and they never turned them off. They would sit at something like 2500 RPM when not in use because the engines didn't make enough heat at idle speed to stay running. When a storm would come through they'd have to dig the running trucks out with wheel loaders. Interesting stuff.
  11. Likes digger doug liked this post
  12. #290
    Jan 2005
    Houston
    5,736
    542
    2524
    Well, sure, diesel trucks. Especially F-250's. Around here, no one turns them off...I suspect even an night they are left idling in people's driveways. There is no greater pleasure than sitting outdoors at an event and having a man - a REAL man - pull up in his F-250 and leave it idling for a couple hours so's we can all hear it and breathe the stinky exhaust.
  13. Likes tdmidget, Trboatworks, Meggab liked this post
  14. #291
    Jun 2019
    Missouri
    145
    68
    103
    Isn't that awesome?
    Happens around here all the time.
    I just LOVE that.
  15. Likes GregSY liked this post
  16. #292
    Nov 2018
    Minnesota
    45
    43
    14
    exactly
  17. #293
    Nov 2018
    Minnesota
    45
    43
    14
    Most long haul trucks run up to and over a million miles. Not all but a lot. The best life came from the early 2000s befor the ridiculous emissions were put into play before they had the technology to Match the mandatory regulations. Now they are getting the mileage and life back to a extent with better materials in the engines and fuel systems. Detroit advertised what they referred to as engine half life of one million miles on there series 60. Don’t quote me but if I remember it meant 50% would run to a million miles without any major work or something to that matter. We have 3 of these all either close to or over a million miles. One has 1.3 on it head has never been off, never had injectors or any computer issues. Not long haul any more either. That’s very close to 40000 hrs without major repairs. So ice’s are not that bad in my mind
  18. Likes digger doug, Scottl, Garwood liked this post
  19. #294
    Mar 2010
    pacific northwest
    1,048
    6
    218
    200,000 miles is one half billion revolutions at 2500 rpm @ 60 mph.
    Modern cars do pretty good.
  20. #295
    Nov 2014
    Florida
    4,045
    1611
    1879
    Yes and math works for everything.... DUH 365 days in a year, 8760 hours in a year, suppose you could just run a brand new car (or 2 by your numbers!) out in one calendar year by that logic!
    edit: you are a dipshit
  21. #296
    Oct 2005
    15,994
    Come to think of it, I never smelled them at -30f.
    Probably as the exhaust is maybe 250f, it goes straight up thru the -30f surrounding air, into the stratosphere.
    Or, because in any temp under -10f, my nose hairs (and boogers.....) freeze.... So maybe I just couldn't smell it.
  22. #297
    Jan 2005
    Houston
    5,736
    542
    2524
    Yes and math works for everything.... DUH 365 days in a year, 8760 hours in a year, suppose you could just run a brand new car (or 2 by your numbers!) out in one calendar year by that logic!"
    I'm gonna assume you wrote your asinine post late at night after you were well drunk and sated with your sister's lovin'. No one could really be as dense otherwise. That is PRECISELY the logic involved, jamoke. A brand new car would last even LESS than one year if driven continuously. Why is that so hard for you to grasp? Oh wait...drunk and sister-lovin'. That's right.
  23. #298
    Oct 2004
    Elyria Ohio
    1,826
    3457
    770
    Hey ... I resemble that comment!
  24. #299
    Oct 2009
    Louisville, KY, USA
    969
    214
    217
    I really like the way world class trolling brings us all closer as a community. Most of this thread has just been people sharing interesting engine stories. It's nice.
  25. Likes eKretz, Garwood liked this post
  26. #300
    Nov 2013
    Eastern Massachusetts, USA
    4,506
    4622
    4619
    Seriously? Suggesting he is guilty of "sister-lovin'" because you don't like his post?
