Is there a "female" screwdriver?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jul 2016
    49
    10
    Default Is there a "female" screwdriver?
    I'm overhauling a couple of Die Chaser Heads that have slotted screws - except the "slot" protrudes from the top of the screw instead of the traditional groove slot. It's sort of a reverse of a normal slotted screw.
    Do I have to machine custom inserts to loosen these screws or is there a set of drivers I can buy?
    Gary
    Langley, B.C.
    1,743
    368
    1016
    Quote Originally Posted by garyrice View Post
    ...Do I have to machine custom inserts to loosen these screws or is there a set of drivers I can buy?
    I've never seen anything like what you're describing but that doesn't mean they don't exist--the world
    is a big place. Would be dead simple to make something that would do the job. Just run an appropriately
    sized slitting saw across the end of a piece of round stock...
    Aug 2004
    Virginia
    2,407
    179
    953
    Female screwdriver? I think Snatch-On makes one.
    Jul 2004
    central NC
    2,579
    30
    663
    Do I have to machine custom inserts ................
    Gary
    So the correct size drill rod with a slot cut into the end won't work? I'm assuming it's recessed so you can't just put an adjustable wrench on it.
    Steve
  5. Likes mike 44 liked this post
    Jan 2007
    Norfolk, UK
    19,284
    14745
    14895
    New one on me too, .what make of die head?
    Dec 2015
    Connecticut
    1,093
    26
    356
    Screwdrivers are typically female, the vodka will fall out of a male glass
  8. Likes Scottl, DrHook, bosleyjr, Joe Rogers liked this post
  9. #7
    May 2017
    FINLAND
    1,941
    531
    881
  10. Likes fusker liked this post
  11. #8
    Jul 2016
    49
    10
    Yes. They are definitely recessed.
  12. #9
    Apr 2004
    Modesto, CA USA
    7,161
    1221
    They do make them for brake work. I think they call the fastener a "nail". It is spring loaded with a cross bar forged onto the each end? Push it in with the tool give it 1/2 turn and it comes out of the slotted hole. It looks like a spin tite with a slot across it. The slot is fairly wide like maybe 1/8-1/4 inch wide.
    Bill D.
    https://www.napaonline.com/en/p/UBP80708
  13. #10
    Mar 2013
    FALKLAND ISLANDS (MALVINAS)
    1,779
    2182
    1142
    Seriously tho, its minutes to make something that'll work. I did for a hard to get to radiator valve.
  14. #11
    Jul 2016
    49
    10
    There are 3 of them. One is marked "The National Acme Company" and the others are unmarked. But all 3 are similar in design. So I suspect they all are the same brand.
    Gary
  15. #12
    Aug 2008
    Sussex, England
    3,424
    12
    759
    Yup they are/were around. A early form of tamper-proofin I guess.
    I have seen a walleted set (6 or 8?) in normalish size ranges made in the old style round bar with swaged out flats to fit a handle form. Ones I saw were a "trades mans issue" toolkit. Dunno who made them. Certainly not in the usual tool catalogues but this was maybe 1990 so before the internet revolution.
    Clive
  16. #13
    Apr 2004
    Modesto, CA USA
    7,161
    1221
    [QUOTE=Demon73;3469968]
    I assume the video is showing the aircraft fastener that uses such a driver. Something like a duz it or cleco?
    Bill D.
  17. #14
    Nov 2013
    Eastern Massachusetts, USA
    4,925
    4883
    4869
    I just checked my rather large collection of "security" bits and nothing even close.
    It must indeed be a special.
  18. #15
    Sep 2010
    Oklahoma City, OK
    4,693
    807
    1937
    With 3 identical this is unlikely but....maybe it's the remainder of a broken off flat blade.
  19. #16
    Mar 2013
    1,779
    2182
    1142
    Quote Originally Posted by Bill D View Post
    Bill D.
    Sorry Bill no, just a play on females driving screws. The tool I made was just some bar with a slot in the end of it. Could loctite a tube over it for a more support if needed.
    Cheers D
  20. #17
    Apr 2004
    Modesto, CA USA
    7,161
    1221
    Plumbers use a special drain wrench to tighten the drain fitting in a sink or tub. Four points to engage the cross bars from the top side.
    Bil lD.
    https://www.homedepot.com/p/Husky-Do...0128/304217585
  21. #18
    Aug 2004
    Virginia
    2,407
    179
    953
    Bill....there is a cleco clamp but that is not what those are. Cleco clamps are installed with a special pair of pliers into drilled rivet holes to hold panels together while more holes are drilled. Or they are used to clamp the panel into position so you can install the rivets. Then they are easily removed using the same pliers. I have about a hundred of them and use them all the time on sheet metal work. Any body and fender repair shop will have a slew of them.
  22. #19
    Sep 2013
    PA
    521
    244
    398
    Gary
    If the screw identifies that way it is, no question about it. If the screwdriver won't work with it's a bigot.
  23. #20
    Jan 2007
    Norfolk, UK
    19,284
    14745
    14895
    Gary
    Think I've found em - very old Namco heads like on this page (the individual pic won't link so look down RHside) Namco Stock Photos & Namco Stock Images - Page 3 - Alamy
