Is there such a thing as an L-000 spindle?
Results 1 to 5 of 5
    Jan 2005
    Southcentral, AK
    2,654
    1721
    Default Is there such a thing as an L-000 spindle?
    Over on the Garage Journal, a British fellow has a French-made lathe, albeit one with the tags and charts in English.
    Anyway, he pulled the chuck off and thought it was an American-style L-type taper...
    ... Until he measured it:
    Small end is approximately 1-11/16", large end about 2-1/8", and has a 1/4" key. He's pretty sure the nut isn't imperial, probably 2.5mm pitch.
    IS there (or was there) such a thing as an L-000 spindle? Or is this some one-off?
    Doc.
    Jul 2011
    Americus, Georgia
    418
    540
    131
    ltypenuts.jpgL type chart attached.
    Jul 2004
    Houston, TX USA
    30,449
    Quote Originally Posted by muckalee View Post
    Thanks to me and ASA/ASME B5.9 Spindle Noses
  4. Likes specfab liked this post
    Feb 2006
    Indiana
    13,013
    698
    3965
    The standard shows L00 as the smallest. But Rivett built lathes with L000 spindles. I expect tooling is very rare, as the size never got popular. See Tony's page that mentions the special spindle nose: Rivett 918 Lathe
    Here is a quote from that page: "The all-important spindle nose was formed as an L000 version of the then popular and effective American long-taper key-drive type - the smallest "official" size being L00, This was a fitting that provided a robust and secure mounting and also allowed high speeds to be run in reverse with complete safety. Unfortunately, as with so many Rivett components, although the dimensions of the nose matched the standard fitting for L00, it is believed that a different thread pitch was used for the retaining ring."
    Larry
    Oct 2013
    Midwest
    60
    11
    20
    Quote Originally Posted by L Vanice View Post
    Here is a quote from that page: "[FONT="]The all-important spindle nose was formed as an L000 version of the then popular and effective American long-taper key-drive type - the smallest "official" size being L00, This was a fitting that provided a robust and secure mounting and also allowed high speeds to be run in reverse with complete safety. Unfortunately, as with so many Rivett components, although the dimensions of the nose matched the standard fitting for L00, it is believed that a different thread pitch was used for the retaining ring.[/FONT]"
    Larry
    That is quite interesting. However, it sounds like the "L-000" from Rivett has the same actual taper nose dimensions, just a different nut? The OP's taper has a big end diameter of 2 1/8" while L-00 (or the Rivett "L-000") has a big diameter of 2.75".
    Here is a post that popped up that may have some relevance(Need help with ID for Lathe spindle nose) The nose inside taper looks way bigger than the one you posted, but the outside may be similar?
