Thread comes out good except for the start and end points. The ends have shark fins?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Mar 2009
    6,604
    131
    1275
    Default Thread comes out good except for the start and end points. The ends have shark fins?
    That's what I'm calling the partial thread at the right and left sides.
    The left side is always worse when there is a shoulder that is deeper than the thread depth.
    How do you trim the shark fin off. The fin is so thin it bends easily and would break off eventually.
    I use a small file with micro pliers. Is there a better way other than applying for a loan to get a CNC lathe?
    Jan 2007
    Mountain Home AR.
    158
    9
    98
    The thin area at the beginning and of the thread can be reduced significantly with a chamfer equal to the thread depth at both ends. Just a square undercut at the end of the thread and a square face causes a very thin leading and trailing edge.
  3. Likes michiganbuck, rons liked this post
    Sep 2015
    Ohio
    1,904
    1233
    2042
    You could also buff them off with a hard gray wheel on a pedestal grinder.
    For the one against the shoulder you may have to undercut the gray wheel so you only get what you want without messing up the OD or other threads. That can be done with an old carbide insert.
    Or in a pinch, I've used the tang side of a file.
  5. Likes rons liked this post
  6. #4
    Jun 2012
    Michigan
    14,351
    4889
    5193
    That is a really nice extension. Likely it takes a little care in use so it does not whip at high RPM. I can think of many times that would have been handy.
    Some fine threading can be aided with a very sharp cutting edge and some positive side cutting edge or back rake. I like side-cutting-edge positive rake because it is easier to fit into your fish.
    Using an insert one made for aluminum is very good/better IMHO.
    Every lathe, grinder or machine cam have a little coming up/take-up to cutting force, and then relaxation of forces at the end of work when the stick removal amount decreases.
    The rigidity of the set-up and cutting tool geometry have a great influence on this problem. Often the rake attitude and sharpness of cutting tools are big factors.
  7. Likes rons liked this post
  8. #5
    Oct 2009
    Louisville, KY, USA
    1,205
    224
    331
    Chamfer at the right end (in the pic) of the threads should be there anyway to help get the nut started. Chamfer at both ends will avoid your problem altogether like Howie said.
    A couple licks with a file while the part is still in the lathe is a nicer touch under any circumstances to remove any burrs that might have been thrown up.
  9. Likes rons liked this post
  10. #6
    Jun 2012
    Michigan
    14,351
    4889
    5193
    I take an OD lick with a hard stone or a file before my final pass. I Might do that for a few passes if I see or suspect a build-up OD, Or to see the thread spec OD flat.
  11. #7
    Sep 2004
    Wisconsin
    286
    79
    Start threading with diam. a bit smaller so there is a flat on thread crest. Chamfer end 45 degrees. Finish thread start with file.
  12. Likes rons liked this post
  13. #8
    Feb 2006
    Indiana
    14,092
    827
    4821
    I make a similar product, using the same Dremel collet nut. But my chuck has a No. 1 B&S taper shank with a drawbar thread. I do not trust the Dremel collets to be accurate, so my chuck has a .125" reamed hole for the 1/8" shank carbide engraving cutters and four slits in the taper. The chuck has a long taper, so no need for a chamfer. The nut has a counterbore at the base, so there is no need for an undercut behind the threads. I cut the .275-40 thread with a Geometric 5/16D die head and 1/4-40 chasers with the head adjusted oversize to fit the nut threads.
    Larry
  14. Likes michiganbuck, JohnEvans, rons liked this post
  15. #9
    Mar 2009
    6,604
    131
    1275
    Quote Originally Posted by L Vanice View Post
    Larry
    When I was in junior high school a tough guy (at least he thought he was) asked me if I was bad. I said no and then he chuckled.
    Well, I think that thing you made is bad. Bad means kool ...
  16. #10
    Mar 2009
    6,604
    131
    1275
    Quote Originally Posted by michiganbuck View Post
    Thanks. The post here might be considered hobby grade if there is a Dremel involved. All this because I don't have a 1/8 collet...
    Just a 3/8 bar with a hole and a thread on one end. For a Dremel chuck and collet. I actually don't like using a Dremel.
    Every time I free hand it I screw a workpiece up. I made this as a alternate to fit in a BP. I inherited a Dremel 212
    drill press stand but never used it, I'm not that interested in using it unless the BP way is "not the way".
    This is what I'm drilling. A breakout board for a 100 pin LPC1769 micro-controller for motor control. This is the first
    board I attempted. The fabric it is resting on is a diaper. Appropriate for first try (a section of copper lifted off at
    the top-upper-right). The lines are not that sharp because I used too many passes through a heat seal rolling machine and
    the transfer image became too hot and the line edges became uneven. The second one is in progress. I have posted a few other
    threads that are all tied to this project.
  17. #11
    Apr 2018
    9,761
    4693
    If you were making a few of these you could set up a rotary table thing and higbee them manually. If you had a lot you'd want to do something more automatic but for just a few it'd be easy to crank around with a small end mill.
  18. Likes rons, MrWhoopee liked this post
  19. #12
    Mar 2009
    6,604
    131
    1275
    Larry
    Very Kool. Now if I was single pointing the thread I would have a line around the circumference.
    But your picture shows an abrupt stop and is much cleaner. I am referring to the thread cutting
    on a Hardy using the quick withdraw lever. Nobody exists that can withdraw that fast to avoid the line.
    (Is this nonsense speak? Does it matter?)
  20. #13
    Feb 2006
    Indiana
    14,092
    827
    4821
    I did cut my threads on a Hardinge, but with the Geometric die head in a lever tailstock. Did you know that you can buy .275-40 button dies on eBay? It is the thread found on type WW 8 mm watch lathe collets. They also have the taps for making collet draw bars. Kind of handy if you want to make more than one chuck with that thread.
    Actually, for less money than the die, you can buy a long straight shank ER-11 collet chuck that would do what you are describing.
    ER11A-100L Collet Chuck Holder Extension Rod Straight Shank CNC Milling Tool | eBay
    Larry
  21. #14
    Mar 2009
    6,604
    131
    1275
    A guy in a hurry. How could he resist that price.
    I recently bought some carbide drills from the UK. Made in China. I was pleased.
    So how can you resist this takeover?
    Pocket book? Not that effective if every choice you see in the store is from China.
    Vote? Not that effective because the political system is setup as one party with two factions.
    Forums? Just use the word ChiComm all over the place to make yourself feel free ...
  22. #15
    Aug 2011
    Oregon
    2,745
    665
    846
    Years ago I started using the edge and flat of a mill bastard file with that the 90 degrees cutting both the front and back of the top flat knocks both burs off the tops, then a few years later I started doing that followed by a pass in reverse so the file runs off the front, as it does it cuts away that knife edge bur.
  23. #16
    Nov 2003
    6,146
    225
    2124
    I don't want to discourage you from having the fun of doing it yourself, but PCB prices have come way down lately. You can probably have that done with a two sided PCB with plated holes for just a few dollars, including the shipping with relatively fast turnaround. You can get several boards with a minimum order. And the design software is available free. Just do a web search.
    As for the threading:
    Dead sharp, HSS cutter
    A good cutting fluid (I like TapMagic for threading)
    Do not use soft, gummy aluminum. Try a T6 alloy.
    Quote Originally Posted by rons View Post
  24. #17
    Mar 2009
    6,604
    131
    1275
    Quote Originally Posted by EPAIII View Post
    Any references are welcome. But I am doing much better than the wire wrap days.
    Wait to you see my 208 pin LQFP socket board.
    (It is very hard for a do-it-yourself guy to pay somebody else to do it)
  25. #18
    Nov 2003
    6,146
    225
    2124
    OK, good luck!
    PS: I also have done wire wrap. It has a place and I made circuit boards that way for professional use. They were totally dependable for years.
    As for paying someone else to do it, I look at the price. You can get several prototype boards for less than the cost of the copper clad you are using. But, have fun.
  26. #19
    Jan 2005
    CANADA
    Saskatchewan
    10,403
    1421
    3826
    I'd typically use a fine grit belt on a vertical sander to remove the shark fin on the outer end of the thread. I do this often to pipe threads cut on cnc. I roll the end of the pipe against the belt, with the belt moving parallel to the thread, so as to not induce a burr on either side of the thread. Fast and works well. Filing during powered rotation on the machine does not work as well.
  27. #20
    Mar 2009
    6,604
    131
    1275
    OK, good luck!
    I looked at pcb houses and have been to conferences and have a folder of business cards and folders. Thing is you have to use their design software which is
    mostly free with windows os. I am free a able with geda-pcb. I get gerbers but have not given up hope on my abilities yet. So I don't pass out my gerbers just
    yet.
