Thread major/minor for apparent M16L-11tpi thread?
Results 1 to 10 of 10
    Sep 2010
    Guinea-Bissau, West Africa
    767
    133
    Default Thread major/minor for apparent M16L-11tpi thread?
    Hi all, a previous thread was closed, hopefully this will be more the the admin's liking.
    Previous thread here: Frustrating nut!
    The consensus was that my pedestal grinder from Portugal (in the 70's, when they were still using some inch stuff) might be threaded M16 but 11tpi. I'm as sure as I can be that it's 11tpi and not 2.0mm - the 11tpi thread gage definitely fits better.
    The major is 0.6299" (16mm). I just used 11tpi thread measuring wires to get a thread diameter of 0.5703". I'm not very experience with non standard threads.
    What will my ID of the nut be (external thread minor dia plus tolerance?) How much will I eventually feed a 29.5 degree compound once I touch off of that bored ID to cut the thread?
    Thanks a lot, a weird thread like this is new territory for me, but I'd like to get my grinder fixed.
    Jul 2006
    Hillsboro, New Hampshire
    10,217
    2386
    7123
    Perhaps the safest way to deal with this is make a test thread on a short shaft that matches your grinder thread on OD and measured pitch diameter. Then use this shaft for fitting the nuts you'll machine. You can make the nuts a little loose to ensure they'll work, a super-close fit to the grinder spindle isn't needed here.
    After you've made the test thread, lay it into the grinder thread to ensure the longer section of 11tpi still matches.
  3. Likes Red James, HuFlungDung, AlfaGTA liked this post
    Sep 2004
    south SF Bay area, California
    2,086
    160
    695
    There's a rule of thumb for determining "tap drill diameter" -- which I'm pretty sure is what you're asking about -- for both the Unified (aka ISO Inch) and ISO Metric threadforms: tap drill diameter = Major Diameter minus Pitch. Using that rule of thumb, your tap drill diameter would be calculated as 16 millimeter minus 1/11 inch.
    1/11 inch is very nearly 2.3 millimeters, making your tap drill diameter very near 13.7 millimeter.
    As for the required infeed of the toolbit . . . it can theoretically be calculated, but it's dependent on the actual diameter of the yet-to-be-threaded hole, the infeed angle, and the length of the flat at the tip of the toolbit. It's a calculation I hesitate to make, and have found it's far more direct to simply make a short counterbore a proverbial hair over the Major Diameter at the mouth of the hole to be threaded. Color the counterbore surface with a permanent ink marker that contrasts with the metal color, use a toolbit with a proper-length flat at its tip, and stop cutting once the tip of the toolbit grazes the color.
    John
  5. Likes JohnEvans liked this post
  6. #4
    Apr 2015
    162
    177
    88
    I could be wrong but Im willing to bet its a 5/8-11 thread.
  7. Likes SAG 180, Illinoyance, Leg17, LockNut, MrWhoopee liked this post
  8. #5
    Jun 2016
    Iowa
    133
    112
    62
    U been trying to figure this out for 2 years?
  9. #6
    Sep 2010
    767
    133
    Quote Originally Posted by kevin66 View Post
    That would be wonderfully easy, but the Dewalt grinder sitting right next to it uses 5/8-11 nuts (one left and one right), and it won't thread. Half a revolution, but once yet get past the chamfer, it won't go any further.
    The RH threaded nut for this Siemens grinder in question, the nut that I do have, will thread onto the 5/8-11 thread of the Dewalt spindle, but the reverse is not true - which makes sense given that this spindle measures over the OD it should for a 5/8-11 thread.
    Wish it were that easy! If I, for some reason, had an M16L-11tpi tap, I'm pretty sure I could run it through a normal 5/8-11 nut and I'd be off to the races. Don't seem to have that tap sitting in my toolbox though!
  10. #7
    Sep 2010
    767
    133
    Quote Originally Posted by StinkyDan View Post
    Living in West Africa for a decade has taught me the value of refocusing on something you *can* push forward when you hit an unsolvable dead end.
    It's also greatly heightened my tolerance for working with half-broken equipment, unfortunately.
    The other side of the grinder works fine, and I have five pedestal grinder spindles in my shop. To be honest, I don't really need the 6th, I just don't like it having beaten me!
  11. #8
    Jan 2005
    CANADA
    Saskatchewan
    10,234
    1398
    3701
    Even a true 16mm male thread probably shouldn't be a full .6299" OD, as any bit of contamination or denting in handling can make the nut want to seize on. Does the male thread appear to have a sharp crest? It might just have a burr raised that could be filed off. I'd probably just file the damn thing down to .624" OD anyways, to avoid having to have a 'special nut' for one damn machine.
    Edit: scratch that, I checked the PD you gave, it does appear to be a bastard metric.
  12. #9
    Dec 2008
    New York
    10,394
    2703
    i have seen rod start out .625 diameter and get bigger cause the dull thread die pushed the metal around a bit and made it bigger diameter like .630 dia.
    dont matter its still a 5/8-11 thread cant get nut on, run a file on it while turning or use a hand thread die. only take maybe 10 seconds either way
  13. #10
    Nov 2017
    348
    231
    236
    Triangular file, thread chasing file or threading die...
    Make it fit a 5/8-11 one way or another.
