Hey all,
I'm wondering if square aluminum bar stock exists 3/8" wide by 1/2" tall that would have 8-32 threaded through holes uniformly/incrementally laid out going down it's length. If you're having trouble picturing it, think electrical terminal bar. Does such a thing exist or would I have to find someone to mill this for me. What I'm trying to do is use the bar stock as a stand off. So far I can only find standoffs that have one threaded through hole. And what I'm looking for is a long strip where I can use 8-32 machine screws to bolt two pieces of sheet metal together separated by 1/2" clearance. This way I don't have to have to use the same stand off hole (top and bottom) for the two screws. A longer bar would allow me to use a full length 8-32 x 1/2" long screw in one hole holding one piece of sheet metal, and in the next hole over I can use another different 1/2" long screw to hold that plate. Instead of using two .250 long screws going into the same stand off. Hope that makes sense. Thanks for the help.
