Threadforming Stressproof
Results 1 to 17 of 17
    Sep 2010
    Oklahoma City, OK
    5,581
    1081
    2435
    Default Threadforming Stressproof
    I have a tendency to break spiral flute taps in stressproof, always on retract in the lathe. I think the material's chip nature is the cause.
    Regardless, I gotta do it. So how well do form taps do in this material? The threads are solely for fixturing so no crazy specs other than don't break off the tap.
    Tips, tricks?
    Edited for clarity.
    Sent via CNC 88HS
    Sep 2004
    Wisconsin
    266
    71
    Use a gun tap. Drill a larger hole for 50% threads. Use sharp tap. Use dark thread cutting oil. If tapping deep clear chips half way.
  3. Likes sfriedberg, Oldwrench liked this post
    Jan 2019
    223
    24
    56
    Quote Originally Posted by Cole2534 View Post
    I have a tendency to break cut taps in stressproof, always on retract in the lathe. I think the material's chip nature is the cause.
    Tips, tricks?
    Sent via CNC 88HS
    I have no experience with this material, but when I am having issues tapping lower quantity stuff, I just opt to use a thread mill. If you have the ability (y axis), it may save you a bunch of headaches.
    Oct 2011
    West-Central Illinois, USA
    1,417
    2264
    669
    Stressproof doesn't like to be cold worked.
    Good luck,
    Matt
  6. Likes Oldwrench liked this post
  7. #5
    Sep 2006
    SW Wisconsin
    759
    241
    280
    I used to do a pile of 1/4-20 and 5/8-11 in stressproof. I used a dab of Moly-Dee in each hole, 1/4 at 500 RPM and 5/8 at 200 worked fine. A fast reverse seems to help.
    Ed.
  8. #6
    Sep 2010
    Oklahoma City, OK
    5,581
    1081
    2435
    Quote Originally Posted by Matt_Maguire View Post
    Good luck,
    Matt
    That's exactly what I was anticipating.
    Sent via CNC 88HS
  9. #7
    Jun 2012
    Michigan
    6,069
    5699
    3879
    What kind of cut taps are you using? Spiral point? Spiral flute? How deep are you tapping?
  10. #8
    Sep 2010
    Oklahoma City, OK
    5,581
    1081
    2435
    Quote Originally Posted by Mtndew View Post
    Spiral flute. 1/4-20, 1/2" deep threads, 1" deep hole.
    Ended up drilling to 1-1/4" deep with a #6 and had no issues usong a spiral point.
    Sent via CNC 88HS
  11. Likes Mtndew liked this post
  12. #9
    Oct 2014
    Maine
    1,335
    268
    640
    Spiral point. 1/4-20, 1/2" deep threads, 1" deep hole.
    Ended up drilling to 1-1/4" deep with a #6 and had no issues.
    Spiral point taps are for through holes; they shoot the chips forward. Spiral flute taps are much better for blind holes.
  13. #10
    Sep 2010
    Oklahoma City, OK
    5,581
    1081
    2435
    Quote Originally Posted by DanielG View Post
    I should have been more clear- I was breaking spiral flutes, the spiral point with extra depth lives.
    Sent via CNC 88HS
  14. #11
    Nov 2014
    Florida
    6,336
    2523
    3137
    Sent via CNC 88HS
    At least by hand (don't have any real info), spiral flutes seem to require more torque so maybe that is a reason?
  15. #12
    Jul 2006
    Hillsboro, New Hampshire
    13,939
    3055
    9230
    I think they require more torque because they use what's essentially a bottoming chamfer length to get the chips formed in a way that (ideally) they flow up the flutes - bigger, fewer chips.
    A more traditional chamfer length like on a spiral point would give more, thinner chips, making it easier to clog the flutes.
  16. #13
    Sep 2008
    2,629
    1963
    1637
    Best way of answering your question is to buy a form tap and try it out.
    If it was me I'd use a spiral point tap and play with the hole dia and depth as you indicated in post #8 Also I'd use a coated tap, TICN coatings seem to work well.
  17. #14
    Sep 2008
    2,629
    1963
    1637
    Spiral flute taps have a smaller cross section so are easier to break. I avoid using them, unless I really have to.
  18. #15
    Jun 2012
    Michigan
    6,069
    5699
    3879
    Quote Originally Posted by triumph406 View Post
    They are excellent taps, as long as you don't need to tap very deep. Notice how every mfg's video only shows their spiral flute taps going minimal depth? Like who the hell is using a 1/2-13 bolt with 3/8" of thread?
    Once you go deeper than the flutes, chips like to wrap around the tap and that makes them snap in half.
    Great taps, limited usage unfortunately.
  19. Likes triumph406, Cole2534 liked this post
  20. #16
    Sep 2008
    2,629
    1963
    1637
    That's pretty much been my experience.
  21. #17
    Sep 2010
    Oklahoma City, OK
    5,581
    1081
    2435
    EXACTLY. With long, stringy chips it's less of an issue. With short, crumbly chips they pack the hole, IME, and block egress.
    Sent via CNC 88HS
