Threading aluminum pipe
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    May 2019
    8
    Default Threading aluminum pipe
    Hi,
    I am wanting to cut and then thread two pieces of aluminum pipe. OD is 1", ID is 0.8". I would inside-thread one piece and outside-thread the other so that the two pieces will screw together, essentially recreating the pipe. There will be no load or stress on this junction - project is decorative in nature.
    Question - is the 0.2" delta between OD and ID enough to allow adequate inside and outside threads?
    Question - what TPI would you recommend?
    Thanks in advance,
    D
    Jul 2006
    Hillsboro, New Hampshire
    14,001
    3062
    9257
    There's little wall to make thread in the size you mention, could some light press fit plastic dowels (even ones that have split ends and have been spread a bit for extra grip) work for this instead? If you need pass-through, how about a modest hole in the dowel?
    Al's not known for liking thread fits that are used more than once, either...
  3. Likes Limy Sami, BoxcarPete liked this post
    Jan 2007
    Norfolk, UK
    21,386
    16754
    17468
    What he said AND if the connection has to be screwed, make female threads in both tube ends and use a (say?) brass connector.
  5. Likes BoxcarPete liked this post
  6. #4
    Guest Guest
    If you have to go with aluminum use as course of threads as possible, deburr the I.D. and O.D. well. I would also lube them before assembly. As Milland said aluminum threads want to be screwed together and left that way.
  7. #5
    Jan 2009
    Maine, USA
    232
    140
    108
    I think it can be done fairly easily. Dividing the 0.100" wall into 3 is roughly 0.033" for material to leave on the ID, OD, and then share in the thread area. 0.033" for threads translates to 16 TPI, which is not even that fine. Aluminum on aluminum does need to be treated carefully as has been mentioned.
  8. #6
    Oct 2005
    22,400
    For-What-Purpose ?
  9. #7
    Nov 2018
    Michigan
    800
    433
    537
    For-What-Purpose ?
    Already mentioned - decorative, non load-bearing.
    In addition to the above, one thing to consider is anodizing. If you want pretty colors for your decorative parts, keep in mind that the anodization layer will grow the parts slightly (amount depends on anodize type). Therefore, you need to cut threads deeper so they will still fit after anodizing. The other thing is that anodized aluminum is much more resistant to galling, so threaded connections will be fine in that case.
  10. #8
    May 2019
    8
    Thank you everyone for your replies. I have some things to think about.
    As another option, I might consider a press-fit connection using a couple of grooves and O-rings on the female end to retain the two pieces. Any input on how aluminum will handle this sort of connection? Would probably require some silicon lube at least.
  11. #9
    Nov 2018
    Michigan
    800
    433
    537
    Quote Originally Posted by digadv View Post
    If you cut the parts to have proper clearances for o-rings and use assembly lube, it will assemble easily... and disassemble just as easily if you don't hold it with something else. You'd be pushing the boundaries a bit as the smallest standard oring cross section in that diameter is 0.070" which would give you somewhere between 0.045" and 0.042" left per side at your grooves.
    Press-fit in aluminum would make the orings obsolete, and it's best done with a thermal shrink. Big side in the oven, little side in the freezer, assemble, and wait for the magic to happen. Actually pressing the pieces together will gall them and you might not be happy about the fact that it's permanently frozen together 1/16" away from being flush
  12. Likes JCByrd24, TeachMePlease liked this post
  13. #10
    May 2019
    8
    Unfortunately the pieces will need to be separated, maybe once a quarter.
  14. #11
    Sep 2012
    California, Ventura county
    2,068
    956
    910
    how important is the id ?
  15. Likes Limy Sami liked this post
  16. #12
    May 2019
    8
    Quote Originally Posted by 72bwhite View Post
    The ID is not that critical. Could be reduced to 1/2". What are you thinking?
  17. #13
    Jan 2008
    New Hampshire
    290
    146
    81
    Not sure if this will work in your setup but here’s something I do routinely.
    I have a hyd hose crimper with 8 finger dies (Gates 707) in our shop. When connecting thin wall pipe or tubing I crimp one end to slip fit, sometimes turning the crimped end for better fit, welding is very rigid after connection too. Think tent poles.
    In your case the crimped end could be crimped less than a slip fit but turn threads, then chase a tap through the other mating end.
    Sometimes we have to get creative if the pipe or tubing is long like laying the crimper down horizontally etc.
    The Gates 707 crimper has a digital readout to adjust crimp diameter real easy. So if you know of any hyd hose guys in your area this could work.
  18. Likes digger doug liked this post
  19. #14
    Mar 2009
    6,370
    124
    1240
    The dimensions you wrote appear to leave enough material for the threads. Some anti-seize compound that is grey would go on the threads.
    Thread the external thread piece and use it as a gauge when running the internal threaded piece. The dimensions leave little room for error.
  20. #15
    May 2019
    8
    Quote Originally Posted by rons View Post
    Quote Originally Posted by JCByrd24 View Post
    I don't think the o-ring concept is going to work so I am back to the option of threading. I've threading before but never joined two pieces of pipe with a wall of 0.2". JCByrd offered some geometry (thank you) and I just want to make sure I do it right. As he stated, the thread area (1/3 external thread, 1/3 internal thread, 1/3 shared/overlap) could be accomplished in 0.1". Does this imply that I should reduce the OD on the male end by 0.05" and increase the ID on the female end by 0.05" before I start threading?
  21. #16
    Aug 2012
    California, Central Coast
    5,361
    2405
    2212
    Why not just thread the inside of both pieces to be joined and use a smaller piece that is threaded on the OD to join the two of them. Use loktite to lock the sleeve into one pipe, never-sieze on the other pipe. Taper the ID of the sleve so if you push wires or anything through it they don't snag there.
  22. #17
    May 2019
    8
    I think that's what I'm going to have to do. Thank you for your help.
  23. #18
    Mar 2006
    jacksonville,fl.
    1,544
    1510
    528
    I was going to suggest as RobF said except I would thread and tap only one end.Green Loctite Retaining compound on the unthreaded end could be as strong as the threaded end depending on the length. Just a little quicker than threading both ends.
  24. #19
    Aug 2012
    5,361
    2405
    2212
    Quote Originally Posted by ratbldr427 View Post
    I thought it might be easier to thread (or buy) fully threaded sleeves. Then he can internal thread the pipes and use the worst internal threads to be loctited to the sleeve. This avoids having to turn down 1/2 of each sleeve or boring half of the pipes.
  25. #20
    Sep 2012
    2,068
    956
    910
    Quote Originally Posted by Rob F. View Post
    exactly threat the inside and make a nipple to connect it
