Threading inserts
Likes Likes:  0
Results 1 to 4 of 4
    Apr 2006
    Arkansas
    35
    Default Threading inserts
    Hi Guys
    I have a Valenite A12-VLER2 boring bar, and I would like to find some threading inserts for it. I can't even find anything on the net matching the bar and so far Walter/Valenite doesn't even show that bar.
    Thanks in advance!!
    Charles
    Feb 2013
    Northern califorina, usa
    239
    70
    Could be obsolete, Maybe someone on the forum has better information then I, that said we have a bunch of odd/old carbide cutters and one time or another I have called many tool holder manufacturers. Some times it takes a bit but more times then not I have found something that would work in it's place or a superseded part number. I have called Valenite direct and found them to be very helpful in the past.
    May 2017
    FINLAND
    1,931
    527
    878
    Valenite v-loc
    http://www.pitstool.com/pdf/l0342.pdf
    Kennametal top notch inserts look much same to me? (Cant say for sure, surfing web on smartphone during flight..)
    Jan 2007
    Flushing/Flint, Michigan
    8,350
    436
    6874
    MattiJ is spot on. Yes, same insert.
    This is a #2 top notch internal threading and grooving bar.
    Valenite part VLT-2 for 60 degree threads.
    Same as Kennametal and other generic NT-2L, just needs to be a #2 and L.
    Here:NT2L - INTERNAL
    and even here: NT 2L Tin Carbide Insert
    plus many on E-yuck.
    A NTP has a 10 degree hook up top for freer cutting. NG series for grooving, others for different thread forms.
    These do not interchange with Sandvick's Top-locks which while the same physical size have a different style clamp groove.
    Bob
