Threading issue
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Threading issue
    Feb 2014
    Canada
    52
    26
    Default Threading issue
    Hi Everyone,
    Hopefully someone can shine some light on this threading business.
    See attached photo. Yikes.
    This is my practice run on 1” round 4140 hardened alloy I just purchased.
    I tried the 4140 annealed and had much the same results, threads pulling.
    In the setup I have currently Arthur R. Warner HSS insert TNMC. I have EDGE level
    to adjust the height. I tried moving the insert up and down with not much change.
    Both inserts are new. Shaft runs nice and true 0.0003” and everything is tight.
    In the picture is a second insert I tried with TPMC (carbide gold color), no difference.
    The speed tried is 65 and 185, which may be the culprit, but since the thread on the final product is 15mm, length of the thread is 16mm and collar beside it is 25mm, I am paranoid going any faster of fear crashing the tool into the collar. (not in the picture as I am just practicing).
    I was even thinking if I need to ran faster to make the shaft where the collar should be, say a 16mm so I will not crash it, and then after the threading if successful press the collar onto the 16mm shaft. Unless of course there is another technique, like cutting threads away from the collar with upside down insert.
    I work mostly with stainless and never run into this to be a bother. So obviously, I am just not capable to machine 4140. I am ashamed of this embarrassing picture.
    Jul 2004
    Houston, TX USA
    31,505
    17 and 48 SFPM on 1" dia. - 350 SFPM would be more like cutting speed. 4140 prehard will thread nicely. Flood coolant or at the very minimum dark cutting oil
  3. Likes Matt_Maguire liked this post
    Nov 2009
    Massachusetts
    508
    168
    Quote Originally Posted by Ratz View Post
    Running in reverse with cutter upside down is exactly what I've done in such close quarters.
  5. Likes Ratz liked this post
  6. #4
    Feb 2014
    Canada
    52
    26
    Quote Originally Posted by johnoder View Post
    Hmm… I may be wrong, but I punched in the numbers. 350 SFPM works out to 22 revolutions per second. Since the length of the thread is 15mm that would give me ¾ of a second to do the cut and stop the spindle before it crashes.
    I can see this speed for turning but call me chicken for threading on manual lathe. Maybe I misunderstand your approach.
  7. #5
    Feb 2014
    Canada
    52
    26
    Quote Originally Posted by Joe Gwinn View Post
    OK, good to know I am not dreaming. I never threaded this way, so I will do some practicing.
  8. #6
    Feb 2007
    St. George, Utah
    1,153
    724
    752
    Hmm… I may be wrong, but I punched in the numbers. 350 SFPM works out to 22 revolutions per second. Since the length of the thread is 15mm that would give me ¾ of a second to do the cut and stop the spindle before it crashes. . .
    I think he must've meant 350RPM.
  9. #7
    Feb 2014
    Canada
    52
    26
    Quote Originally Posted by Gordon Heaton View Post
    That would make sense. I will see what the cut of thread looks like at 350 and go from there. As I said
    185 made me nervous so I just may practice the upside down method going outwards.
    Thanks for coming up.
  10. #8
    Jul 2004
    Houston, TX USA
    31,505
    350 RPM on a 1" dia is 92 SFPM - suit yourself - but I do see the carbide cutting tools which will be happy at 22 revs per second or 350 SFPM
    You will need a relief groove to start in
  11. #9
    May 2010
    DENMARK
    4,079
    4126
    12884
    A good rule of thumb for a thread groove width is 2 times pitch.
  12. Likes Ratz liked this post
  13. #10
    Nov 2009
    Massachusetts
    508
    168
    Don't try this if your lathe has a threaded spindle. Having a spinning chuck unscrew itself and chase you around the shop is far too exciting for one's health.
  14. Likes climb-101, Ratz, Bobw liked this post
  15. #11
    May 2010
    DENMARK
    4,079
    4126
    12884
    That sounds like the voice of experience You don't just happen to have a video?
  16. #12
    Jun 2019
    South Dakota
    71
    16
    20
    I have threaded a lot of 4140 both annealed and hardened, almost every day. screws down to no.6-38 ( if memory serves) and up to 2"-12 always on manual lathes. first, high speed steel properly ground and sharpened is much more forgiving on speed, second a good lard based oil, or even baking lard ( I use it constantly) or dark cutting oil, applied every pass, will help keep your cutter clean, the metal welding to the end of the tool is your worst enemy. My dad threads even slower than I do, I have in the past ran as slow as 65 rpm on 1" bars with good results, just takes a lot of time and light (.005 or less) passes. first pass can be deeper, but need to get lighter with each pass. getting proficient with threading is all in practice...... and good cutting oil, don't be stingy with it!
    by the way I threaded the no.6 at less than 100 rpm, speed helps but it's not necessary for a beautiful thread. ( I made thumb screws for a browne and sharp 38" vernier caliper I bough my dad for Christmas,both fit better than the ones in my starrett and looked better too!)
  17. #13
    May 2017
    Massachusetts
    397
    440
    204
    Can't tell from the photo, but how much stick-out? You keeping it under 3x diameter?
  18. #14
    Apr 2005
    Beaverdam, Virginia
    9,457
    1275
    4879
    I thread a lot of 4140 both annealed and prehard from 1/2" to 1 3/8". I always use Kennametal grade KC5010 it has given the best combination of life and finish. That is on a CNC Lathe using water soluble flood coolant. For 1" threads I would go 500-600 rpm. The right insert I have found is very important. I have a 3.5" long thread I single point at 1,000 rpm, Kennametal NJF3008R20 KC5010 will usually get 200+ on each insert side. The same style in a KC730 will barely make a dozen parts.
  19. #15
    Jan 2005
    CANADA
    Saskatchewan
    10,235
    1400
    3709
    Hi Everyone,
    You tried 'moving the insert up and down'? What the hell for? Set it slightly below centerline height and it should cut. Looks like you've got it set above centerline, and that just ain't gonna work in this universe.
  20. #16
    Feb 2014
    Canada
    52
    26
    Thank you good point. I am OK there as my chuck is 8" D-4.
  21. #17
    May 2011
    southern in.
    1,579
    2092
    419
    John, I think he is using High Speed Steel (HSS) inserts. May be a bit of confusion.
    JH
  22. #18
    Feb 2014
    Canada
    52
    26
    Thank you. There should be hope for me then. I just keep trying with different tools. Interesting is
    that my HSS insert by Arthur R. Warner never failed me in 316 and 304 stainless.
  23. #19
    Feb 2014
    Canada
    52
    26
    Quote Originally Posted by Dumpster_diving View Post
    This is my latest trial. Still crappy. Material is sticking out 1.25". Using TPMC carbide 180RPM. This is a second try without chamfered start on this piece of alloy. It was late last night and I forgot.
    Come to think of it this is my first fine thread. Course threads always came up nicely in stainless.
  24. #20
    Feb 2014
    Canada
    52
    26
    Quote Originally Posted by HuFlungDung View Post
    I have tried moving insert up and down, just to see if being below and above centerline would make a difference in cut. I have included a picture of EDGE level for everybody to know, that I am using some decent tools to find centerline. Other convincing fact of being on the centerline is during facing I have no nipple left what so ever.
    I will keep in mind your advise being slightly below is preferred. Thank you for posting.
