Hello, I am trying to thread some PETG plastic rod which was 3d printed. I need to end up with an adapter of sorts having a threaded M4 0.75 and M5 0.8 portions on opposite ends. To that end I am 3d-printing approximately 5mm PETG studs and attempting to thread them using some metal dies I had on hand. However, I've already gone through dozens of studs without getting workable results.
I don't have a heavy-duty vise, so I'm using a drill to hold the PETG studs while I attempt to thread them from the opposite end with the die. The studs have a conical taper to make it easier for the die to catch. Eventually it does catch, but whatever speed of the drill I use (I go nowhere near actual drilling speed, that would quickly heat up and deform the plastic), and what pressure I apply, I end up with very mangled threads. Obviously every time the die spins too much without moving forward, it annihilates the freshly cut threads. But I cannot figure out how to prevent that.
The weirdest thing is that the first time I tried threading one of the studs, by hand, it worked pretty well and I assumed it would be easy. I've since not been able to get it right though. I am very new to machining and I'm afraid I don't know how to go about getting this done. Could someone please explain a reasonable method for threading this soft plastic without destroying the threads? Would really appreciate any ideas!
