Threads coming out with an angle
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    May 2019
    Nebraska
    Default Threads coming out with an angle
    Hello, I have a small Grizzly G0750G lathe that works well for most things. I知 currently working in threading some muzzles, and I have noticed that the threads all have a forward angle towards the muzzle. Things thread on fine, but the angle bothers me. Any idea how to fix this? I知 not sure how to post a photo.
    Compound is set at 29.5 degrees, tooling is square to the work piece via fish gauge. 60 degree single point threading
    May 2005
    Republic of Arizonia
    1,577
    460
    Purchase a better machine or figure out how to tighten or fit your lathe to remove any slack backlash or looseness in the machine itself.
    That being said hobby machines are not allowed here..
    Please use generic terms while referencing hobby equipment.
    Jul 2003
    savannah, jaw-ja
    1,726
    1178
    404
    Some compounds are marked differently - the crank should be at about 5 o'clock when you look straight down on the compound, i.e, 29.5 off perpendicular to the spindle axis, or stated another way 60.5 off the spindle axis.
    If you had it the "other" way - say 3:30 or 4 - i.e., 29.5 off the spindle axis, infeeding with the compound would give the results you describe.
  4. Likes gusmadison, MetalCarnage liked this post
    Feb 2005
    9,032
    13770
    10682
    Quote Originally Posted by Rudd View Post
    At least 10 times a year.. The SAME EXACT THING.
    "I know its set right"
    "no its not"
    "But it says 29.5"
    There was just one of these threads a couple of weeks ago..
    I don't understand how its so hard to visualize that if you are
    feeding in at a steeper angle than the thread flank, you are
    going to wipe out the thread flank. Especially when somebody is
    literally sitting there and WATCHING it happen.
    Feb 2007
    St. George, Utah
    855
    384
    543
    Quote Originally Posted by Bobw View Post
    . . .I don't understand how its so hard to visualize. . .
    Well, people see what they expect to see. Some 'authority' said 29.5* so . . .
    For the O.P. :What isn't usually mentioned is that part about every lathe not being marked the same way. Another way to 'look' at it is that the compound slide must be at the same angle as the right-hand edge of the thread cutting tool. In other words, line a ruler up with the right flank of the cutter and it should extend parallel to the compound. If it slashes across the compound at a noticeable angle, it isn't right.
    Now I know that lining anything up with a tiny cutting edge can be difficult, but in the case of alternate degree markings the difference will be obvious.
    May 2009
    Canandaigua, NY, USA
    2,849
    138
    1255
    I've had the problem when everything is set up right. Check the tool height and check that the clearance angles are sufficient.
  8. Likes old_dave liked this post
  9. #7
    Nov 2003
    4,965
    174
    1518
    I posted some instructions on posting photos here:
    Using This Board's Image Hosting
    There are other methods, but that will get you started.
    Quote Originally Posted by Cattleman99 View Post
    Hello, I have a small Grizzly G0750G lathe that works well for most things. I’m currently working in threading some muzzles, and I have noticed that the threads all have a forward angle towards the muzzle. Things thread on fine, but the angle bothers me. Any idea how to fix this? I’m not sure how to post a photo.
  10. #8
    Jul 2004
    Houston, TX USA
    29,638
    Common sense helps too. If you on purpose set the compound at a low angle in relation to spindle axis it will produce crap threads - every time
    The common sense tells me that if I want to feed the tool along the flank of a 60 degree thread profile, I had better have the compound set about 29.5 OFF THE FACE OF THE FACE PLATE - never mind what it says on the degree index
    ON EDIT
    Hint - pick up that little "fishtail" tool Mr. Starrett made for you - and slap one side of the point against the self same face (chuck, face plate, dog driver) with fish tail pointed back at you and look at the picture that makes. THAT is the same picture you want the compound to make
  11. Likes JohnMartin, Bobw, James H Clark liked this post
  12. #9
    Aug 2005
    Tucson AZ
    6,283
    9400
    2948
    Guess those barrels are fucked up. Why would you do that to a finished part not knowing what you are doing?
  13. Likes jrmach liked this post
  14. #10
    Aug 2012
    California, Central Coast
    3,408
    2167
    1328
    Quote Originally Posted by JS View Post
    I think that Grizzly IS allowed ONLY in the gunsmithing sub-forum. Since the OP is doing work on a gun barrel he could have posted outside of his sub-forum by mistake?
    Otherwise I agree, do not mention the unmentionable machines here.
  15. #11
    Aug 2012
    3,408
    2167
    1328
  16. #12
    Aug 2015
    Illinois
    1,371
    988
    587
    It seems to me that OP should have learned to single point thread BEFORE working on firearms.
  17. #13
    Jul 2006
    Hillsboro, New Hampshire
    7,367
    1737
    5121
    Quote Originally Posted by Illinoyance View Post
    If I had my face and fingers near an exploding charge, I'd want to be pretty sure I knew what I was doing before trying to change anything...
  18. #14
    Oct 2005
    14,858
    Quote Originally Posted by tdmidget View Post
    Well it threaded on "OK"...so that's all that matters....
  19. Likes dalmatiangirl61, TeachMePlease liked this post
  20. #15
    Aug 2012
    3,408
    2167
    1328
    He said it was on the muzzle so probably wont ever have to unthread it. More like, find the part (muzzlebrake?) downrange.
  21. Likes TeachMePlease liked this post
  22. #16
    Jun 2019
    237
    75
    199
    Quote Originally Posted by Rob F. View Post
    Some JB Weld will take care of that.
  23. Likes dalmatiangirl61 liked this post
  24. #17
    Aug 2015
    Illinois
    1,371
    988
    587
    Ideally he would cut off the messed up threads and re-thread the barrel, assuming the barrel would still be legal length.
  25. #18
    Virginia
    26,787
    7561
    8377
    Maeah,, Darwin's ghost still has to eat...
    At least firearms are not as much "in your face" as cellphones, motorcars, drugs, congenital idjuts in their "all of the above" combination, yah?
    Population got lazy. Thot we could clean-up our local communities by sending various tribes of truants off to Washington, DC to bugger each other, leave us in peace?
    Darwin's ghost is like to die young - health issues off over-eating.
  26. #19
    Sep 2010
    Oklahoma City, OK
    4,245
    728
    1783
    Since the burning is a deflagration instead of detonation I don't think it's technically an explosion.
  27. #20
    Dec 2012
    AUSTRALIA
    2,000
    9
    611
    Its a muzzle brake,worst can happen is its flying downrange........red loctite is your friend...........some say you got to be crazy to set off powerful explosions inches from your head...not me.
