helmbelly
- Mar 12, 2013
- New Orleans
I have a Vertex 8" table with 3 slots. I've been looking to see if anyone made a bolt thru chuck (6" 4 jaw independent) that had 3 holes to save a bunch of work and an inch of Z axis (Rockwell knee mill).
The chuck just needs to work hold mostly alum and delrin so I don't need much. I found an asian POS chuck with the right 3 hole config made of "semi steel" a term I have to google...
8" D1-4 4 Jaw Independent Lathe Chuck
but the chuck I found is not a thru hole just an internal socket on the bottom side.
So I had a couple ideas
First just remove platter from rotab and bolt thru to the underside of chuck and reinstall platter or
the other idea- pick up the holes they have and blow thru to use T nuts.
Just wondered if I'm missing anything basic before diving in. I'm self taught and what I don't know is impressive.
