Brett W
Cast Iron
- Jan 10, 2014
- Huntsville AL
After spending the last three days not making money and fixing my old used lathe, I'm fed up enough to buy something new. Bought this JFMT 360 six years ago for $1200ish, its a wreck. There is .018 measured wear on the leading way on the cross slide, so when making a heavy cut the whole cross slide deflects and makes the tool dive. Parting is a hell of a lot of fun with that, pucker up. I have made my money and more with it so its time for someone else to buy it and get it out of my shop.
I am looking for a manual machine, 14-18in swing. Haven't really run into a situation where I needed more than a 40in C-C in the time I have been using my lathe. My current machine weighs 2700lbs. The new machine must weight at least 3000 preferably more. Currently looking at the following:
Acer 17x40s
ACER Group Homepage - Engine Lathes [E-lathe 1740G/1760G/1780G]
ACER Group Homepage - Engine Lathes [Dynamic-1740G TO 1780G]
Acra
https://acramachinery.com/product/1640te-precision-gap-bed-engine-lathe-12speed/
https://acramachinery.com/product/1740ace-precision-gap-bed-engine-lathe/
Webb
MA-1800 series | Webb Machinery
Whacheon:
https://whacheon.com/downloads/HL-460_18inch.pdf
Not sure whats up with the spelling, but pretty sure these are the same machines:
http://www.hwacheon.com/en/product/product_machine1.do?strCode1=30001&strCode2=&intPrdSeq=10250&tab=
Doubt I can afford the last two, but will investigate pricing.
Not ready to step up to CNC, nor do I think that I need a CNC yet as most of my parts are 1 off, repair parts, simple enough to be made efficiently on a manual machine, and I have a friend with a TL2 for productionish type projects.
I run my own race car/fabrication shop, so the need to walk over and make something, happens pretty much every day. I'm figuring I'm going to have to spend $15-20k to get something nice.
Not going to waste my time dealing with the current used market. "Old American" iron is over priced and usually so worn out I may as well keep what I have. The used machinery dealers remind me of used car salesmen and just sell garbage for silly money. If I am paying silly money, at least I get something new, not crashed, not worn out, not rotted, etc. Plus it has a warranty. The used guys just want your money so they can move on to the next sucker. (maybe I am jaded dealing with the machines I have looked at and the dealers I have talked to in the past)
The companies above seem to have been doing this for at least 30+ years, there is legacy support, parts are available, etc. (not that I expect to need parts on a new machine)
Anyone in the Southeast have or used these machines? Can I come test drive it? Broken one lately? Major complaints?
Looks like the tail stock spindle on all but the Whacheons is a bit on the small side. My current one is 68mm (I think). Spindle through holes appear a bit small, but 2.125in would be nice at least.
Looks like D1-6 is common and easy to support for chucks. Guess straight gear drive is better than the odd inverter drives, but no Constant surface speed support is a bummer. (not sure it matters). Some have no indication of pressure fed oiling, but surely that isn't the case for the head stock (saddle I assume is splash with a pump to feed the ways and cross slide.
Chip tray doesn't seem removable, is that a big hassle? I can remove mine currently, but usually just shovel it out. 1800rpm seems reasonable, I rarely use the 2000rpm on my current machine. I am running insert tooling currently and will transfer that to the new machine.
Thoughts? I'm sure I should be going CNC, but even a TL2 is going to be 35k landed on the floor and fully functional. Not sure I'm ready to buy a used CNC lathe. Probably will start with a used CNC mill over the next few years though. My Index 745 still gets the job done.
Acer 17x40s
Acra
Webb
Whacheon:
