madmachinst
Stainless
- Jan 15, 2007
- Central FL
say I needed 200 of these made and the workpiece is 4130 aircraft seamless tubing 9/16 OD by .393" ID 9.5" long. I need 5" of the ID at 11mm diameter very smooth. The rest of the ID is .450" rough drill finish will suffice. OD is machined to .531" and there is about 5/8" length of NF thread on there with a small slot going through the thread. Tolerance on the 11mm bore is +/-.001" the slot is like +/-.015" and the rest is +/-.005". Anyone got any idea how long this would take you to make, what kind of equipment you would plan on using. I would like to hear from the manual folks and the CNC folks.
