ORAGRAG
- Oct 29, 2002
- Lino Lakes, Minnesota
I am looking for a air compressor control that has the ability to adjust the differential to as low as 10 psi. Max pressure would be 180 PSI. Everything that I have found has much higher differential settings. I would perfer to have a digital control so I can visually see the settings instead of guessing. Anyone know of a off of the shelf source.
If not the only other option that I can think of is to build somthing using independent adjustable pressure switches. Any help would be appreciated
Nick
Nick
