I need a couple timing pulleys to replace the steel rusted ones on my parts catcher on my cnc lathe. I really just need the blanks I can machine the inside bore features. The belt is a HTD style with a 5mm pitch and 15mm width.
The pulleys are a 24 tooth and a 48 tooth with no shoulders or belt guides on the sides. Do any of you guys have a source for these also as I mentioned the OEM ones are steel would aluminum be sufficient?
Thanks for any help
Thanks for any help
