HandyNotHandsome
- Jul 30, 2018
I need to hand tap some 3/4-14 NPT threads into a piece of 6061 aluminum tubing which is 1.125" OD and 0.995" ID (this ID is larger than the normal ID for tapping 3/4-14, this is fine for my purpose). I've tapped smaller stuff before - up to 5/16" - in aluminum and steel without problem, but this job has some issues:
First, how to grip the tube? The tap is extremely difficult to turn, and a strap clamp proved useless. I can't get a good enough grip with the pipe wrapped in a protective sleeve of leather, with vise grips or channel locks. The only tool I have at my disposal that grips tightly enough is a pipe wrench, but the teeth on this cut deeply into the soft aluminum. I have a 4-jaw chuck, but I don't think I can't get a tight enough grip without distorting the tube.
Second, how to align the tap? I don't have a T-handle tap wrench big enough to hold this tap (the base is maybe 11/16" across the flats). My trial run doing this involved using a pipe wrench for the tube and a vise or vise-grips for the tap. Used plenty of cutting fluid, and a new tap which feels pretty sharp. Backed the tap out a half turn occasionally. The result was deep marring on the tube from the pipe wrench, some distortion/crushing of the end of the tube from the amount of torque I was using, and threads that are noticeably off from true alignment with the axis of the tube.
Any tips on tools or jigs/fixtures or technique for doing this job, without spending a lot of $$? I came into this thinking that tapping threads (even 3/4" threads) in an oversize aluminum hole should be a cinch, so I'm wondering if I'm doing something wrong.
