Mike Hill
Cast Iron
- Aug 28, 2004
- upper michigan
Is there a way to attach a piece of carbide to a titanium bar such as a silver solder or brazing operation, mechanical means won't work, this assembly will take alot of pounding, current setup is a steel bar with the carbide silver soldered to it. The steel bar has a 60 degree angle cut into it to acept the carbide which has a matching 60 degree angle.
any help would be apreciatted
