Clive603
Titanium
- Aug 2, 2008
- Sussex, England
For pretty much all the 16 years I've owned it my 2J2 Varispeed Bridgeport head, 1 1/2 hp motor, has had occasional rattle fits. Which I put down to just one of those things given its a 1979 vintage machine. Recently it has got regular enough and loud enough to make investigation essential.
On strip down I discovered that the fixed varispeed disk on the motor has no key fitted. Clearly the disk had been mostly supported by the pressure of the belt holding it against the lower motor bearing. Over the years the sleeve has run independently enough to grind off maybe 1/8" off its hub and to start wearing flats on the ball cage of the motor lower bearing! I'm amazed that it didn't come to grinding halt years ago.
Was little surprised to see that the disk bore and the part of the motor shaft it sits on appear to be metric dimensions.
The bore in the disk itself has worn sort of hour glass shape. The taper end is about 25.4 mm Ø and the hub end about 25.7 mm Ø. The wear tapers seem to be about the same. The motor shaft measures 25 mm Ø where the sleeve goes. About 5 mm between the taper wear seems still to be close enough to correct diameter of 25 mm to feel a sliding fit on the shaft but not close enough to stop it wobbling.
My proposed cure is to bore out maybe 10 or 12 mm from each end and fit either a tolerance rings or thin steel sleeves bored in situ to fit the shaft so it is properly supported at both ends. Looks like a tolerance ring needs about 2 mm overbore whilst I figure I can get a glued in place sleeve in 1 mm overbore. Only 3 mm depth of keyway in the sleeve so a full length sleeve or tolerance ring will probably thin the keyway down too far. Tolerance ring has the advantage of gripping the shaft which should take some of the load off the key. But the grip may make installation difficult.
What does the team think is the best way to proceed?
Either way boring out concentrically at each end is going to be interesting. Presumably a tolerance ring will be slightly more tolerant of error than a sleeve.
I had to re-make all the moving varispeed disk bushes before putting it into service. Very pleased to see that my efforts are still holding up just fine after 16 years. I can only assume the fixed motor sleeve was still apparently securely fixed on its shaft when I did this so I saw no reason for a deeper inspection that would have revealed the missing key. According to the folk I got it from, the rump of InterCity Machine Tools, they had re-built that machine some years before for a previous owner when they were still actively in the machine reconditioning business.
If the sleeve is beyond sensible fixing plan B is to convert it to VFD and timing belt drive. I have a "professional" VFD conversion kit removed from another machine but don't approve of the control aspects. A lot of electrical re-jigging will be needed to make a satisfactory conversion integrated with the other control aspects. As supplied I suppose the kit might do for a Myford!
Clive
Clive
