clarnibass
- Dec 23, 2015
Hi
I repair musical instruments and recently watched this video
YouTube
Starting at 0:45 you can see the brass tube (cone) over a steel mandrel is drawn through... something. This is a common method to make trumpet tubes and I guess many other things. I've never seen it done for a tube, or rather a cone with such a taper.
I'm wondering how that works i.e. how whatever it is on the outer side can change the diameter but still push against it? Someone suggested that it is lead and just deforms to press against the tube? Is this the standard method? I'm colourblind so not sure if the material in the video is even metal (looked like it but looking again it has a weird colour compared with steel).
YouTube
