Tool post twists !
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Jan 2020
    CANADA
    New Brunswick
    11
    Default Tool post twists !
    No matter how tight I tun down the locking screw , my tool post rotates very slightly when turning between centers! The post is an "A2Z" qr post with an "A2Z" tool holder using a carbide (removable)tool and the work is a steel 3/4 in. dia. bicycle pedal crank. I have tried a short extension on the 3/16 in. locking screw Allen key with no success. The lathe is an EMCO 8 in..X 18 in.
    Jun 2015
    Colorado
    527
    1091
    185
    Make yourself a solid toolpost mount. After seeing Robin Renzetti's implementation on his HLV-H I did the same with my Emco Super 11. Made a huge difference in rigidity as well as tool repeatability. Been planning the same on my 10ee. Go check out his video on YouTube.
    Apr 2004
    Modesto, CA USA
    7,167
    1222
    On my BXA I had the same problem until i bought a dedicated 16" long box wrench. I really have to pull on it, hard, for hard cuts. I bet over 50 foot pounds or more. The hold down bolt is 16mm so about 5/8.
    3/16 is 7 foot pounds to tighten it. I would say 10-15 foot pounds to prevent rotation. You could even try a clean piece of typing paper sandwiched under the base.
    Bill D
    Sep 2008
    Canada
    1,045
    425
    402
    Have you checked the bottom of the toolpost is flat without burrs/crud? Is the top of the cross-slide flat also without burrs? Have you tried the old trick of paper between the toolpost and cross slide?
    If all that fails... I bought a Dickson toolpost years ago for my Colchester Chipmaster that had an extra hole at the edge of the block. Don’t know if the factory did that or prev owner, but was useful to spot a hole into my cross slide for a pin. No rotation :-)
    Lucky7
  5. Likes Hopefuldave liked this post
    Mar 2005
    Indiana
    4,429
    1048
    957
    Not sure what kind of force your cut is applying, but on a big American lathe at my last shop, the Aloris (DA) regularly rotated on me during heavy roughing cuts (~ ⅜"-½" per side, .030" to .040" feed). I finally got fed up and made a locking plate to go under the toolpost. It was keyed to the slot in the top of the compound and had dowel pins that located in the bottom of the toolpost. That did the trick. If we needed to rotate the toolpost to a weird angle would just remove the plate. Sounds like that is what Bug is talking about too.
  7. Likes BugRobotics liked this post
  8. #6
    Jan 2005
    Houston
    5,873
    587
    2683
    I don't get it. I have a CXA that I tighten with a normal 1-1/4" wrench (because that's what fits the nut) and it is dead solid with almost no effort. Sometimes...I forget to tighten it much at all and it still does OK.
    I think your T-nut/stud or whatever you have is not being allowed to clamp properly. Maybe the stud is bottoming on the carriage before it can tighten.
  9. Likes sfriedberg, MetalCarnage liked this post
  10. #7
    Oct 2005
    16,614
    Quote Originally Posted by Dead Eye View Post
    Emco Compact 8 Lathe
    Looks like no "tee" slot.
    As stated above, check that your not bottoming out, running out of threads, etc.
    I would replace the socket head capscrew with a threaded rod, putting a nut on top.
    YouTube
    shows some odd looking plastic wingnut on top....
    EDIT: BTW what are the numbers on the cut your attempting ?
  11. #8
    Nov 2013
    Eastern Massachusetts, USA
    4,933
    4894
    4870
    Is that one of those hard anodized QC tool posts that A2Z makes?
    If so your best bet is to strip the tool post down, mount the body in a 4-jaw chuck and turn a shallow rebate near the center hole. That will transfer the clamping force to the outer parts where it can more easily resist torque. I had the exact same problem with one of those and rebating the center (maybe 3x the diameter of the central hole) cured it.
    I think the hard anodizing makes them slippery.
  12. #9
    Nov 2003
    5,197
    184
    1665
    Here is a link to that video:
    YouTube
    It is a great video about a great mount. He has a very good understanding of what is going on when a tool post is mounted.
    Quote Originally Posted by BugRobotics View Post
  13. Likes BugRobotics liked this post
  14. #10
    Nov 2003
    5,197
    184
    1665
    My shop made tool post is not hardened. There is no problem with rotation, even with heavy cuts. Perhaps hardened tool posts are the problem.
    But, for added rigidity, I may make a mount similar to the one in Robin's video to eliminate the compound. That sounds like a capital idea. Capital!
  15. Likes BugRobotics liked this post
  16. #11
    Apr 2007
    mays landing NJ
    531
    469
    146
    Try this first as it is quick and easy. Cut a piece of sandpaper to fit the tool post. Grit doesn't matter. Install between the tool post and the compound.
    Many mini- type lathe instructions mention this when the tool post moves.
    I did this for a youngster who was given a small used lathe and had the same problem. Worked out well for him.
  17. Likes Hopefuldave, Mtndew liked this post
  18. #12
    Jan 2020
    CANADA
    New Brunswick
    11
    Thanks for the tip. R.R.'s creation looks like just what I need but is beyond my abilities. Where do you get a 6 inch cube of cast iron? I will try to work something out but would like to see your version.
  19. #13
    Jan 2020
    CANADA
    New Brunswick
    11
    Thanks Mike. Sounds like an excellent idea. Try the easy stuff first !
  20. #14
    Jun 2015
    Colorado
    527
    1091
    185
    Hi, cast iron blanks can be purchased from McMaster Carr. Here is the one I made for my Emco Super 11.
    I couldn't bring myself to modify my Aloris toolpost so I bored the dowel pin hole into a Phase II toolpost. I wouldn't have that hesitation the 2nd time round.
    Attached Thumbnails Attached Thumbnails 2018-02-11-10.39.19.jpg   2018-02-11-10.46.03.jpg
  21. Likes trevj liked this post
  22. #15
    Oct 2003
    East Peoria, IL, USA
    5,414
    353
    808
    Your tiny lathe doesn't need a 6" cube. Nor does it need to be cast iron. Even an aluminum block would be FAR stiffer than your compound because it has no moving parts. Expand your search to include "any hunk of metal remotely the right size" Or, stop being such a total cheap skate and BUY a hunk of metal.
    The set screws and pins from the sides, fancy sculpting, etc... are nice but largely unnecessary. You will gain the most from simply not having the moving parts, gibs etc... simply replacing the compound with a flat bar of the same height will drastically stiffen your tool.
  23. Likes digger doug, BugRobotics liked this post
  24. #16
    Sep 2010
    Oklahoma City, OK
    4,693
    807
    1937
    B7 or better, not the cheapy zinc plated shit from the 5 and dime.
  25. #17
    Oct 2005
    16,614
    Quote Originally Posted by Cole2534 View Post
    Naw, got to use TiAn coated "Sooper Billet" all thread.
    No polishing to that turd anyhow.
    What's nice is, when all is said & done with, the Op can simply tuck that LSO under his arm, and carry it to the skip....
  26. #18
    Jul 2004
    Houston, TX USA
    30,465
    Quote Originally Posted by eKretz View Post
    Yep if you spring for a real tool post it comes with at least one free dowel hole in bottom
  27. Likes number 2, eKretz, Hopefuldave liked this post
  28. #19
    Jul 2001
    North Carolina
    1,984
    184
    410
    A2Z tool posts are micro-lathe home hobby size toolposts.
    Yyyyaaaawwwwnnnn!!!!
    -Doozer
  29. #20
    Oct 2005
    CANADA
    Ontario
    1,151
    258
    401
    My Dickson QCTP was moving while trying to do some knurling on my Super 11.
    Made a holder from a hunk of 12L14 and pinned the old 4 way to the top, it bolts right to the cross slide in place of the top slide.
    It moves no more...
  30. Likes BugRobotics liked this post
