beckerkumm
Hot Rolled
- Aug 5, 2014
- Wisconsin Rapids WI
The screw on my 1024 tool slide is very worn, much more than the one on the cross slide. It isn't fatal as I can tighten gibs for most turning but replacing it is on my list for when I need to advance the compound.
S and B uses a 3/8-10 LH which narrows the choices. There are standard 1018 screws with no tolerance numbers for travel deviation, there are " Precision .009/ inch SS screws, higher precision .003 screws but hard to source in LH, and ground screws that seem overkill for a tool slide ( .0005/ inch ).
The price difference going to the .009 SS isn't so bad but is it worth it to try to find a higher precision screw ? The two backlash nuts should still be OK as they still adjust the non worn part of the screw but will a new screw need new nuts to match ? The rest of the machine is Whitworth but I think the Acme standards are the same as here in the US. I will probably buy the screw and test the nuts but if there is advice on the screw and profile, I would appreciate the help. Dave
