moonlight machine
- Nov 19, 2007
- marysville ohio
I start with a 72 lb piece of 7075 and end up with a 12 lb fairly complex part, lots of triangular pockets 4" deep. a 4" bore with a .0003 tolerance and lots of other fun stuff. I only need to make 4, 2 of one type 2 symmetrically opposite. The pockets are mostly through and have 1/4" radius corners. thought about having some end mills made, 3/4 loc 4.5" solid carbide with a reduced shank diameter so it does not rub on the pocket wall. Planned on drilling the pockets first. What are you using for end mills in this sort of application? I'm thinking I am going to have a bit of chatter going on.
