Tormek DBS 22 opinions
Likes Likes:  0
Results 1 to 6 of 6
    Sep 2015
    Minnesota
    117
    19
    Default Tormek DBS 22 opinions
    Hello,
    Our industrial fabrication shop is looking to invest in a drill bit sharpener(as well as cnc machining.) Typically, we don't use any drill bits larger than 13/16. Usually 5/16, 7/16 and 9/16. I would say it would get used once a day on average so I am not looking for something too expensive and fancy. I looked into Darex 390 and had mixed opinions and they only go up to 3/4. Looking for something a little more accurate and quicker than hand grinding.
    I did a search and didn't find much on the Tormeks. Can their attachment be setup to fixure a regular bench grinder? My intentions are eventually to purchase a bench grinder. Use one side for drill sharpening and design a 2" belt sander for the other side.
    thanks,
    Josh
    Dec 2006
    the Netherlands
    226
    34
    I have a Tormek but not the drill sharpening attachment. I've seen it, but found it too expensive. Hand grinding works for me. I think it could be adapted to a bench grinder, but since the Tormek system is very different it will take some work to adapt it. If you consider a Tormek: the grinding action is slower than a bench grinder because of the water cooled grind stone. The results however are excellent especially on woodworking tools.
    Aug 2016
    AFGHANISTAN
    Tormek have a jig that attaches to grinders now from memory. As for the belt attachment look up the multitool. I know a bloke who makes an attachment to put a longer belt on it too
    http://www.multitoolaustralia.com/products.html
    Sent from my SM-N910G using Tapatalk
    May 2020
    Arizona
    Quote Originally Posted by Piek View Post
    Curious if you've been using the drill sharpening attachment and what you think of it?
    Feb 2007
    St. George, Utah
    1,274
    823
    862
    In all honesty, for general fabrication in the sizes you list, none of the dedicated sharpeners will be faster than hand grinding on a belt. And while hand-grinding does require a bit of care and finesse, so do the specialized grinders! They really only shine when you have large numbers of the same size to sharpen.
    I'd say pick your most apt worker and assign that person 'drill duty'. If you must have split-points, that is yet another skill but it can be done manually too.
    Jul 2019
    UNITED KINGDOM
    21
    6
    I've got one of the DBS22 on my tormek, it works fine once you have it set up correctly, you can do a quality 4 facet grind on it easily. It's an expensive add on, if you dont already have the tormek then I would look elsewhere. I'm unsure how well this would work with a traditional bench grinder as the tormek is a slow speed grinder and a bench grinder may be too aggressive with it.
