Clive603
Titanium
- Aug 2, 2008
- Sussex, England
Been asked to look into prototyping a retrofit device needing two electromagnetic clutches.
Proper industrial rated clutch units will make the device too expensive for its market but car air con pump clutch units look to be within budget. Trouble is that there doesn't seem to be any easily accessible hard data on how much torque they can transmit.
Somewhere between 10 and 20 ft lb at between 1,000 to 2,000 rpm ought to open up enough of a market for the device. Obviously the higher power that can be transmitted the bigger the potential market but anything past 20 ft lb won't make much difference.
The clutches will be engaged under light to no load conditions, unlike an air con pump which engages at full load, so odds are it will be fine to push the continuous loading somewhat above that normally needed to drive a running pump. Especially as the user will almost certainly never deliberately demand full motor rated power for any period of time.
My handwaving calculations suggest design continuous torque transmission of these units is likely to be something over 5 ft lb with significant overload capability before slipping. Which looks promising. But it would be nice to know before I commit to doing a lot of work.
Clive
Clive
