Yes, I'm just trying to grind HSS lathe tooling, etc.
Not the best of choices, then.
A new Taiwanese, or used, Deckel/Alexander/Gorton-Lars SO type, "maybe" a "Cuttermaster" - I am simply not "hands on" with one, ever/so-far.. is far the better and more otherwise-useful deal.
A collection of SEVERAL cheap-ass HF 8" spindles is what I actually USE. Smooth-running ones get the good wheels, rougher-running ones mount the wire-brushes and muslin buffs.
I might WISH I had a Royal-Oak, KO Lee, or Cinncy T&C cutter grinder or even an Oliver of Adrian, or an over-tooled Gardner, Parker-Majestic, or Gallmeyer & Livingston SG.
But I don't NEED any of those, nor can spare the space.
Grinding in general is a speciality. To be any GOOD at it, one has to have "current" experience, LOTS OF IT, and more choices of wheels, workholding, alignment, chucks, heads, coolant systems, dust collectors and "Oh, BTW", multiple grinding MACHINES, not just the one.
I don't HAVE that, and I
KNOW I do not. I don't want to divert time, funds, nor even space, to GETTING it.
It makes more sense to send anything that actually NEEDS precision ground badly enough OUT to he who
does have it, and has it ALL.
Ask michiganbuck or cash masters what it would take to duplicate a decent grind shop from a bare slab.
"Sight unseen" I can pretty well ga-ron-f**king-tee you $1,200 would not even pay for the phone calls to order the equipment, arrange for power, and schedule the installation by the time it was making sparks. There are not a lot of "half measures" in that business that make good sense.
Stay down in the basics: Baldor or similar plain-Jane-spindle, Deckel SO/clone, Darex / Glendo with diamond lap, and that's about all you can effectively put to use before the cost or time invested against the "learning curve" takes you away from any other projects AT ALL.
Look at member Ballen. He has "discovered sex" in the form of a neat and seriously precise cylindrical grinder.
When the only tool you have is a hammer? He's precision-grinding every damned thing within reach he can even fit into that grinder, whether it NEEDS ground or NOT! You'd have to understand sex, I guess. Or at least cylindrical grinders?
