Transferring Drawing from Paper to Sheet Metal?
Results 1 to 17 of 17
    Dec 2005
    Wisconsin
    2,005
    500
    668
    Default Transferring Drawing from Paper to Sheet Metal?
    What ideas might any of you have for transferring a small drawing to a piece of sheet metal? I have a small star washer type thing that I'd like to make. I can easily draw it in ACAD, about 1" or so in diameter. Fabrication would be done by drilling, sawing, and then die filer. I'm thinking something like send the drawing to the printer on a piece of mylar, then use an iron to heat transfer the drawing onto the sheet metal. Would that work? What other ideas are out there?
    Alan
    Dec 2008
    Portsmouth, England
    937
    320
    608
    What's to stop you using Spraymount or equivalent to stick the drawing to the metal then cutting round the outline? Use a fairly stout paper or thin card to it doesn't lift and wrinkle too readily.
    George
  3. Likes Limy Sami, digger doug liked this post
    Nov 2007
    WV
    288
    55
    118
    It might not work for such a small item, but I always just prick punched the outline and connected the dots. I like Georgineer's idea better
    Nov 2011
    2,200
    1414
    2833
    They make aerosol'ized layout fluid / dykem type stuff. For some parts, I've set it / clamped it on there and sprayed lightly around it. Doesn't work well if the bottom surface isn't flat and reasonably sharp.
    Sharp scribe and a steady hand.
    Or glue + card stock, like they said.
    Hell, now that I think about it, we have a laser etcher here that we use to cut cardboard and mylar with - mylar would be great because you can spray all the oil/coolant you want and not care.
    Feb 2006
    Indiana
    14,050
    818
    4794
    I have adhesive-back blank shipping labels from UPS and FedEx that can be laser printed or run through the copy machine. Print the full size design, rough cut around the outside with scissors and stick it to the sheet metal. If the design leaves too little paper stuck to the metal, it will peel off while sawing.
    For delicate stuff, I put the design on thin tracing paper and attach it to the metal with super glue. You can also glue several layers of sheet metal together with super glue and cut a number of identical parts at once. Acetone will dissolve the super glue when done.
    Larry
  7. Likes bryan_machine, Georgineer, snowman liked this post
  8. #6
    Mar 2011
    Denver, CO USA
    10,223
    58
    5704
    I'm old...carbon paper.
  9. Likes andrewmawson liked this post
  10. #7
    Oct 2010
    Oregon
    5,818
    5788
    2248
    Carbon paper is a lot more difficult to find these days. Not so many manual typewriters in use.
    If you do transfer the drawing via carbon paper, pounce wheel, or other powder-based technique, shoot the surface with a light coat of Krylon or artist's fixative to keep the marks from rubbing off while you're working on the part.
  11. #8
    Jul 2004
    Houston, TX USA
    32,393
    Paper prints stuck on with varnish in bandsawing these pattern parts
    Castings look good
  12. Likes digger doug liked this post
  13. #9
    Jan 2007
    Norfolk, UK
    21,388
    16758
    17542
    Quote Originally Posted by johnoder View Post
    Castings look good
    That works for me as well, simple and time proven takes a lot of beating
  14. #10
    Sep 2008
    CANADA
    Ontario
    323
    157
    180
    Quote Originally Posted by adh2000 View Post
    If you haven't printed from ACAD for direct template use before, just be aware that some printers are not good at printing actual size. Also, some print settings will automatically scale what you print. When I am printing from a new computer or to a new printer, I always include a 1"x1" square in the drawing. Once it is printed, I measure that square to ensure it came out as 1"x1" on the paper.
  15. #11
    Nov 2003
    6,069
    219
    2096
    I do sheet metal parts all the time. I print them on full sheet size label stock which you can get at any office supply store. I have a printer that has a straight through paper path (rear to front) so the labels don't peel off inside the printer. Most printers will allow thicker stock to pass through them than the specs. seem to permit. Most printer drivers also allow X-Y adjustments to be made so the 1:1 print size is really 1:1.
    You need to remember to allow for bends when you lay out any part that is not completely flat. I found the best way to do this was by experiment.
    I paste that label on the sheet metal and cut, drill, punch, bend, etc. When the part is done, I spray with WD-40 and let it soak for a few minutes. Then peel the label off and wipe any remaining adhesive off with a rag. It usually comes off very easily.
    Having the label on the part while you work also protects it from scratches and other shop damage so the result looks a lot better. And no scribbled lines.
  16. #12
    Feb 2016
    Alabama
    67
    10
    6
    on all my layouts on sheet metal I just use a sharpie permanent marker, wipe off the metal, cut out the pattern hold it down with a magnet trace around it. when you get rid of the marker mark you have your pattern. jonathan
  17. #13
    Dec 2008
    Portsmouth, England
    937
    320
    608
    Quote Originally Posted by L Vanice View Post
    I have adhesive-back blank shipping labels from UPS and FedEx that can be laser printed or run through the copy machine...
    I wish I'd thought of that!
    George
  18. #14
    Jan 2005
    CANADA
    Saskatchewan
    10,403
    1421
    3825
    I send the drawing directly to the laser guys and they send the part back
  19. #15
    Dec 2008
    Portsmouth, England
    937
    320
    608
    Quote Originally Posted by HuFlungDung View Post
    Nice idea, but most of the laser guys I've come across wouldn't get out of bed for such a small order.
    George
  20. #16
    Jul 2004
    Southeast Michigan
    6,940
    276
    1763
    Amazon.com : Saral Transfer (Tracing) Paper yellow for reverse work, good on metal 12 1/2 in. x 12 ft. roll : Fabric Iron On Transfers : Office Products
    Graphite paper for metal. Works pretty reasonably.
    I've done as Larry suggests as well....numerous times. Used to do it all the time with piercing my jewelry projects. Cheating...possibly.
  21. #17
    Jan 2005
    CANADA
    Saskatchewan
    10,403
    1421
    3825
    Quote Originally Posted by Georgineer View Post
    George
    Yeah, but they might cut you a pail full for $150 and then you've got spares
  22. Likes Georgineer liked this post
