terramir
- Jun 7, 2014
- Los Angeles, CA USA
I have this shaft about 14" long that is one inch thick , except for a section towards the middle that is a little less and the ends have teeth to join with parts. I'm thinking this was from a ford transmission not sure which one thinking f150 e4od input shaft maybe
Now if I'm using a pulley system (think drill press speed system) and I would want to put it on the part of the shaft that is less diameter I would have to shim it so it would run true, but in the beginning I guess I would put a pulley on the rear where it has a true 1" diameter.
More interesting to me would be what bearings I should use, should I use roller bearings or bushings like maybe cast iron or bronze (oil-lite kinda things).Was thinking concrete or an i-beam for a base and two 3/8 flat stock for ways, albeit it won't be 3/8 by the time I mill and scrape the surfaces, although I would go real easy on that don't wanna lose too much mass.
I have seen people use cheap pillow blocks / like 4 of em for the head stock, But I would like to go more in the right direction there, what do "real" lathes use? cast iron bushings? roller bearings what would be the solid solution.
terramir
terramir
