Trick to grab round object in mill vise if their radius is more than the jaw height?
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Sep 2010
    Guinea-Bissau, West Africa
    739
    131
    Default Trick to grab round object in mill vise if their radius is more than the jaw height?
    Does anyone have a clever way to clamp a piece of round stock lengthwise in the mill vise if the centerline of the object is higher than the vise jaws? I need to drill and ream some holes in 5" OD pipe, and would normally secure it with hold downs, but wondered if someone had some great trick for doing it more easily.
    I don't know how I ever clamped short pieces in my horizontal bandsaw until I had a half circle of heavy pipe to do the job, for example - and wondered if there's some great trick or jig I'm missing for this application.
    May 2017
    Massachusetts
    324
    329
    161
    I'm sure others will have neater solutions, but I would go the hold-down route. Use the vise jaws to stabilize and align the bar stock then use a strap clamp from on top to hold it down and secure it.
    Interested to see what others come up with.
  3. Likes Jerry liked this post
    Jan 2014
    Temecula, Ca
    2,910
    1302
    3748
    put it in the vise with the ends facing the jaws
  5. Likes lionelt liked this post
  6. #4
    Sep 2010
    739
    131
    That, at least, is better than my hold-down only route, which would require reindicating the tube every time I have to slack the clamps to slide the tube further through for the next hole a yard later.
  7. #5
    Dec 2015
    Illinois
    437
    144
    251
    3 inch tall vise jaws. It might squish out of round though.
  8. #6
    Apr 2009
    Beaver County Alb. Canada
    1,857
    533
    906
    V Blocks and a stop.
  9. Likes RC Mech liked this post
  10. #7
    Jan 2007
    Norfolk, UK
    18,953
    14455
    14531
    Hold downs on each end fixed to a long (say) piece of channel section that can be gripped in the vice.
  11. #8
    May 2018
    New York
    65
    57
    50
  12. Likes npolanosky, ranchak liked this post
  13. #9
    Jun 2013
    305
    149
    128
    Bore a pair of split clamps from scrap aluminum and tighten the clamps in the vise.
  14. #10
    Jan 2015
    Wisconsin
    23
    Since you mentioned you have to move the work a yard to drill the next hole I would make up some taller vise jaws. Maybe machine a slight V in them so you can use them on multiple diameter round stock that wont fit in the vice normally.
    If you had enough travel on your table you could use a 2 piece vice.
  15. Likes Red James liked this post
  16. #11
    Jun 2012
    Idaho
    3,147
    1734
    2052
    Most tables have little V's at the top of the slots
    do away with vice and clamp directly to the slots
    They are accurate
  17. Likes ratbldr427, RC Mech, sable liked this post
  18. #12
    Langley, B.C.
    1,705
    354
    999
    Quote Originally Posted by jrmach View Post
    ...Most tables have little V's at the top of the slots
    do away with vice and clamp directly to the slots...
    That works great for smaller stock. As the diameter of the workpiece increases it can be a bit difficult to
    line it up on the slot--still doable in most cases.
    For most situations like this I just made up a few different sets of higher jaws. Easy to do with some cold-
    finished flat bar. They work fine unless you're doing something that requires super accuracy--then you may
    need to have them ground...
  19. #13
    Nov 2010
    Tustin, CA
    391
    229
    116
    Tall soft jaws with either V blocks if you have them, or mill Vs into the jaws for repeated uses.
  20. #14
    Jan 2017
    Oregon
    2,683
    474
    1900
    I have ran a lot of larger diameter round parts in vises. I made some tall steel jaws that had about a 5 degree angle on the inside faces.
    When the vises were closed, the jaws came together at the top but left a gap at the bottom. Whatever diameter I was holding didn't matter- the material sat on the bed of the vise and the angled jaws prevented it from lifting up. The same jaws worked whether it was 2" or 8" diameter material.
  21. #15
    Jan 2006
    Angier, North Carolina
    2,613
    1103
    978
    With considerable trepidation, I will offer a suggestion / question. Warning: this may be brilliant ... or hopelessly home-shop-harry.
    Recently I was fixing up an old woodworking jointer for my sister's partner, and needed to hold the tool head body (the part that the blades mount into) in my vice in order to put a key way in the shaft that runs through and powers the tool head. Due to considerable age and many years of abuse or neglect, I really needed to put the key way in at a very particular place on the shaft. However ,the tool head body, while an overall round shape, has various flats and cutouts that prevented secure clamping with the shaft positioned as I needed it. So ... I decided that I needed to make a simple jig, basically two 1" or so thick squares with a hole through the faces large enough to hold the tool head, and a slot cut out of one side to allow clamping pressure. But rather than mill this jig out of some scrap steel or aluminum, I decided to draw it up and print two copies on my 3d printer. (Drawing it up took < 5 minutes; printing it out took an hour or so while I worked on other things.)
    Long story short, the resulting jigs/clamps worked extremely well. I am quite sure they were not precise down to +/- .001", but based on the results, they must have been precise at least to +/- .005", which was plenty good enough for what I was doing.
    So, what says the collective wisdom of the pros - would something like this ever be considered or used in a commercial shop, or is it, as I suspect, strictly a home-shop solution?
  22. Likes jrmach liked this post
  23. #16
    Jun 2012
    Idaho
    3,147
    1734
    2052
    Homey..........
  24. Likes awake liked this post
  25. #17
    Jan 2013
    Plainfield, Indiana, USA
    1,747
    1329
    928
    2 cold finish 1 x 4 x 6 (or longer) flat steel bar with two holes each drilled to match my Kurt vise hole pattern will hold up to 8" dia rounds. If used often, case harden and grind for long term use.
  26. #18
    Nov 2003
    5,061
    176
    1562
    You wanted a trick so here is one. It uses two pieces of uneven angle.
    I am sure it is for light duty only. And it may be more trouble than it is worth. Both angles need to be held down by the round so the two fill blocks should be the same thickness.
    Personally, I would just clamp it. But that would require removing the vise and putting it back again when this job is done.
  27. #19
    Nov 2011
    Alberta
    480
    50
    118
    I would take an angle plate and clamp it to the table. Then I would clamp the pipe in such a way that would push the piece down and against the angle plate. If you dial in your angle plate it should be plenty repeatable if you want to slide it down for your next hole. When I was an apprentice my boss would always frown on putting everything in the vice. he said to many machinists become vise dependent.
  28. #20
    Mar 2006
    jacksonville,fl.
    1,132
    957
    378
    I have some parallels I made that are ground the same height as the base of the vise. I.25" thick x 8" long,c/bored to clamp to the table slots and some 1/2-13 holes in the top to fix hold down bars.I put back fences like a mag chuck to serve as stops if needed.You can add threaded holes in the sides and ends for extra hold downs.
    Really large stuff the vises come off and bolt to the table, some times some plate in the slots to serve as a squaring/back stop.
  29. Likes jeffers liked this post
