Hey guys - we are owner/operators trying to rig a roll on a belt press for removal - then install a new one. The one with yellow arrow in attached picture. As you can see it’s in a tricky spot. We have an overhead crane that can lift and pull from the side that the picture was taken. The other side is mostly restricted for access but we can get in there a little if needed. There is a pan above the rolls that prevents any overhead help underneath - it cannot be removed - and there are the rolls underneath that must remain. Also it is important not to damage the coating on the rolls during removal and install of the new ones. The rolls are roughly 10’ long and 12” diameter. The coating is similar to a thick enamel.
We can move the roll to the left as needed.
Any ideas?
We have all the typical rigging equipment - web slings, chains, hoists, come alongs, etc
Thanks a lot
Any ideas?
Thanks a lot
