dazz
Stainless
- Aug 20, 2006
- New Zealand
Hi
I have a simple problem that should have a simple solution.
I need to notch the end of a 25mm square tube to be welded to a 25mm round tube.
Tolerances are wide. The material is mild steel. I want to use a mill-drill with an MT3 taper.
I tried a 25mm hole saw but it was a failure. The saw did not like the one-sided load and nearly destroyed itself.
I then looked for an annular cutter. I have ER tool holders so I needed a straight shanked tool. I can't get them here. All I can get are Weldon types with so many cutouts in the shank, I don't think they would work with ER collets.
The local price of MT3/Weldon annular adapters is obscene at $USD250.
3MT Adaptor - Annular Cutter - Evolution - Drills Taps and Dies Ltd (DTD)
The exact same item is available from Amazon for 1/5th the price.
Steel-Dragon-Tools-Magnetic-Adapter]Page Not Found but one of the reviews says there is no spring loaded guide rod holder.
Then I found CDCO tools who stock an MT3/Weldon end mill holder for just $18 which does have a draw bar, but it is 1/2", not M12. It also appears that end mill holders are not the same as annular cutter holders.
The most promising option looks like the one here at Amazon
What should be a simple problem has turned out not to be. Is there a better solution?
