tubing "bead" tool
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Jan 2007
    Florida
    1,184
    150
    429
    Default tubing "bead" tool
    not sure of the nomenclature as this is not exactly a bead. 3/8" steel tubing. "bead" is 5" from end of tubing. what tool is used for this? and is there a way to do this economically in relatively small numbers? (25-50)
    it is a stop so the tubing is inserted to a calibrated position (dipstick tube)
    Oct 2005
    17,787
    Have a looky in here:
    Mastercool Inc., Manufacturer of Air Conditioning, Refrigeration, Service Tools and Equipment
    and maybe you can just make your own dies, adapt to a small hydraulic press.
    Jan 2007
    Florida
    1,184
    150
    429
    thanks, however i already own that tool and it does a different style "bead" at the end of the tubing only - won't work further in. this looks like the tubing is pulled together to form a "ridge" for lack of a better term
    Aug 2012
    California, Central Coast
    4,415
    2284
    1767
    If you had 2 of those tools you might be able to do it. clamp both to tubes with the required gap and one end of both tools in a vise and the other gets a big c clamp, tighten both to crimp.
    Or in a press with a larger pipe over your tube to push the top tool if not to far from ends.
    Apr 2004
    Modesto, CA USA
    7,490
    1311
    Or slip on a ring of steel wire and solder it into place.
    Aug 2007
    Idaho
    1,506
    213
    483
    They likely hydroform them, this might help though.
    bead forming tubing
    Oct 2005
    17,787
    Quote Originally Posted by cg285 View Post
    Gee...why didn't you post this little pearl of info in your OP ?....
    Mar 2009
    Brunswick Oh USA
    4,628
    5255
    2765
    There used to be a tool used in plumbing. It put a bead in 3/8 od copper supply lines for lavs and toilets. The rod was drilled and a cam end inserted. When you twisted the L shaped handle the cam pushed a steel ball outward making the ridge. I still have it somewhere (I think). That held a brass washer in place under a rubber washer.
    Jan 2007
    Florida
    1,184
    150
    429
    i have no idea what you would come up with. i have other tools that don't work either
  10. Likes DrHook liked this post
  11. #10
    Jan 2007
    Florida
    1,184
    150
    429
    Quote Originally Posted by Bill D View Post
    not the way this was made but that just might work, thanks
  12. #11
    Mar 2005
    Indiana
    4,770
    1260
    1199
    If you have the capability to "roll your own" tooling you could really easily make something like this with slight changes to put the bead wherever you like:
    YouTube
    Probably would need something like Ray's description for the inside of the tube.
  13. #12
    Jul 2010
    Joliet Il
    95
    30
    33
    You maybe could make or modify something like the Earls beading tool to make it work at that depth.
    edit- tried to add a link, but it didn't work- just google Earls beading tool.
  14. Likes cg285 liked this post
  15. #13
    Jan 2007
    Florida
    1,184
    150
    429
    Quote Originally Posted by Keyepitts View Post
    hmm, says only with alum tubing
  16. #14
    Apr 2004
    Modesto, CA USA
    7,490
    1311
    You could cut rings of the next size tube or buy brass compression rings. By the time you calibrate the ring forming machine you would be time and money ahead for only making 25. Fire sprinkler plumbing does similar but they roll a groove into the steel pipe from the outside. So it is the reverse of what you want. Hydroforming comes to mind as well. Some car headers are hydroformed from tube.
    Bill D
  17. #15
    May 2009
    Wyoming
    3,399
    8347
    5490
    Circular heating via induction coil followed by compression from the ends.
    If you just have a few to make you can do it in an old lathe. Spin it while heating with a torch and then compress with the tailstock.
  18. Likes Garwood, neilho liked this post
  19. #16
    Apr 2002
    Syracuse, NY USA
    9,776
    19
    597
    Perhaps a bulging tool. Ie a urethane plug that expands while two external bores restrain the rest of the tube.
  20. Likes eKretz liked this post
  21. #17
    Jan 2007
    Florida
    1,184
    150
    429
    Quote Originally Posted by Oldwrench View Post
    i'll give that a shot and see how it works. if not then solder...
  22. #18
    Jan 2007
    Florida
    1,184
    150
    429
    lathe trick worked. not as prominent as the sample but doable. a little time consuming.
    i guess the way the original was made is a well guarded secret - like rubber molding
  23. Likes Oldwrench liked this post
  24. #19
    Jun 2019
    421
    133
    382
    Is there a bead on the inside of the tube as well? If so it might be a hint that it was 2 pieces of tubing friction welded together.
  25. #20
    Mar 2014
    Michigan
    546
    100
    324
    Thanks for the followup. Interesting that the lathe trick worked, and it looks pretty good.
    When I look at both photos of the original bead, I can't help but think I see a seam and wonder if it is two pieces, pressed and soldered, or friction welded.
