Wanted to get some input on the finish I am getting using some plastic media in my tumbler, in my opinion it is not nearly as good as the finish I was getting with ceramic. The reason I went with plastic is I pretty much only tumbled aluminum parts and I needed to buy more media since I was only running the tub roughly 1/3 full. I was happy with the appearance using ceramic but the feel was a bit rough and everyone said plastic for aluminum and not ceramic, so I bought 100 lbs of plastic
I just want to know if the finish I am getting with plastic is on par with what everyone else gets. At this point I have ran the plastic stuff for about 10 hours. The finish does feel a little bit smoother but I do not like the look. Another downside I have discovered is the green foam, I have been needing to keep an eye on it/scoop it out to stop it from overflowing in the water bucket.
Not sure if I need to break it in longer or if I should have bought a different shape or if I just need to go back to ceramic
Machine - Burr Bench model 2016
Ceramic Media - Mission Abrasives P40 angle cut tri star (their general purpose ceramic)
Plastic Media - Mission Abrasives green plastic triangles (sold as their less aggressive perfect for aluminum media)
