Toolbert
Stainless
- Nov 29, 2003
- Vashon Island, WA
I'm spending enough time at the sandblast cabinet that its poor performance is wasting too much time, & need to make it work better. It's a Cyclone brand generic cabinet with a recirculating siphon blast gun & foot pedal valve. It has a 14cfm nozzle and is supplied by a 24cfm compressor. I'm using a mix of dupont starblast and 60 grit garnet. The air is dry, but the cabinet is in an outdoor shed where I can't control humidity - but at the moment it's bone dry summer in the PNW.
Its problem is what I think is called surging, where it gives a good strong jet that just peels off whatever its aimed at - for about 2 seconds, and then blows air for 10 seconds while another slug of abrasive works its way up the feed tube.
I can feel the mass of abrasive - the nozzle really pushes back in my hand when it's blowing a good abrasive stream, and barely at all when it's feeding poorly.
I've tried varying the pressure from 70psi to 120psi. Seems to work better with higher pressure, but surges more. Below 90psi it doesn't surge but it feeds hardly any abrasive and takes as long to clean a part as with the surging.
I googled for this topic and found only a few useful pages. One is the TP Tools page for an upgrade kit:
http://www.tptools.com/pl/Images,US-30_L,22,2320_USA-Cabinet-Gun-Upgrade-Kit.html
that shows a different style siphon tube, with the bottom of the air tube crimped down I assume to increase the velocity and stir up the abrasive to make it flow better into the suction tube. I made one that looks like it and it works a little better, but still feels like it's feeding way too little abrasive. Of course it's not exactly the same.
Anyway, it'd be helpful to know how it's supposed to work. Wish there was some way to compare how much abrasive was flowing. Looks like this style of gun is supposed to run around 90psi, but what works for you? Any tips on making a better feed tube? Some other web sites say the abrasive has to be dry "or else", am I wasting my time with an outdoor setup?
thx
Bob
thx
Bob
